How To Seal This? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 02:22 PM   #1
How to seal this?
When the furnace turns on air comes pouring out of this gap? Is this normal or should be be closed up?
Thanks.
Tatertot is offline   Reply With Quote
Old 05-22-2013, 04:41 PM   #2
Rewards Points: 12,830
There should have been a foam seal under that flange.
Or at least some foil duct tape.
Old 05-22-2013, 05:13 PM   #3
Rewards Points: 242
use 100% silicone chalk. cut tube with small opening,
apply and let set up before turning on.
hvac instructor is offline   Reply With Quote
Old 05-22-2013, 06:26 PM   #4
FClef's Avatar
Rewards Points: 160
Use foil duct tape to seal it off. I would not suggest using silicone caulk unless it was of the fireproof variety seeing as you are very close to the heat exchanger and the excessive heat may break down the normal silicone caulk. But foil duct tape should work just fine.
FClef is offline   Reply With Quote
Old 05-22-2013, 07:36 PM   #5
Rewards Points: 614
yep foil tape will take care of that......
carmon is offline   Reply With Quote
Old 05-22-2013, 08:05 PM   #6
Rewards Points: 744
100% silicone tolerates heat pretty well....which is why it's so popular in the kitchen now.
Seattle2k is offline   Reply With Quote
Old 05-22-2013, 09:01 PM   #7
biggles's Avatar
caulking tube or roll check Graingers #6JD51 and more screws their rubberized backed tape that you can run around the top of that furnace opening then drop the duct there down and screw away.any duct tape right over the screws will dry out and you'll be back .the pressure of the air especially in the heating mode is right off the fan and the highest in the system
Old 05-22-2013, 09:04 PM   #8
Rewards Points: 582
go to ace hardware get a roll metal tape ..it will do a good job....just be neat... ben sr
Old 05-22-2013, 10:02 PM   #9
Rewards Points: 242
Foil tape is good if put on neat. I've seen tape that was 4" wide to seal
a little seam. If put on right it can look good. Mostly it looks crappy.
You will not see clear 100% silicone.
BTW it looks like it can be screwed down more.
Old 05-23-2013, 04:57 PM   #10
Rewards Points: 24
Funny seeing as I had the same concern a few months ago. Like everyone noted I put some spare metal tape I had over it.
I also had another question. For my furnace instead of the solid pipe/union I have a yellow shielded flex line going in and it smells like a tiny bit of gas at the entrance. Is that normal? I was doing ceiling work upstairs and was near a register that was directly above the furnace and could of sworn I smelt a tiny bit of gas as well.
knight508 is offline   Reply With Quote
Old 05-23-2013, 11:20 PM   #11
I went the ugly tape way... Even though I have some silicone caulk sitting here. (I checked its rated up to 400 F) I just felt the tape was easier and I don't care how it looks.
Thanks everyone for the tips and help. This site rocks.
Old 05-24-2013, 01:24 AM   #12
I'm Your Huckleberry
Rewards Points: 2,270
ul listed foil tape is all you need. What I want to know is how did it come to be that those connections were not sealed..??
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-24-2013, 07:43 AM   #13
Not sure. I just purchased the house last year and I've been busy with a newborn. Just getting around to all the fun house projects. But my guess is the builder the home is only 7 years old.
Old 05-24-2013, 09:00 AM   #14
Rewards Points: 6,652
Foil tape, since your A-Coil sits in there, and makes it easy to remove it for service, where as with caulk, you have to run a knife around to separate the plenum from the unit.
Old 05-24-2013, 09:02 AM   #15
Can you post a shot farther back, showing the unit from the floor to the supply plenum. Looks like they placed the B-Vent in front of the access panel for the A-Coil. You can start a "blog" in project showcase to keep everyone posted on happenings and what you are doing with the changes, to make the home yours.
So how did the other projects from 2012 turn out?
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 09:49 AM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
Fernco wax free toilet seal question? masterblaster4 Plumbing 2 07-21-2011 11:56 AM
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 10:22 PM
To seal or not to seal tops of IPE rocketdoctor Building & Construction 3 09-20-2009 01:04 AM
