How To Safely Remove A Section Of Gas Baseboard In Kitchen - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 01:43 PM   #16
An old Tradesmen
Rewards Points: 7,746
Originally Posted by Sephora View Post
But warm air from other rooms won't come in? How about the wall unit that cooled off my whole entire 1st floor?
So what I am saying is that my kitchen is in the middle of the house and sort of open. I guess I am assuming that the other rooms that have plenty of heat will make up for it.
How much money to you want to spend on your assumption. It cost more to install new baseboard, then to take it out.
If your kitchen wasn't he hottest room in the house. then once you remove that baseboard, it will become the coldest room in the house. or, the other rooms around it may become a bit cooler also, since they will be losing heat to the kitchen. And their baseboards weren't sized to heat the kitchen.
Old 09-28-2010, 03:39 PM   #17
Sephora's Avatar
Rewards Points: 150
I know...but bottom line is I need to remove that section as new cabinets are being installed there.
Sephora is offline   Reply With Quote
Old 09-28-2010, 04:40 PM   #18
An old Tradesmen
That doesn't prevent a toe kick heater from being installed.
I know, I know, your friends won't mind looking at the new cabinets while their wearing their coats because it cold in the kitchen the other rooms. While thinking you can't afford to turn up the heat now because of all the money that you put the new cabinets.
Good luck,
and stay cool.
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 07:32 PM
Cabinet Removal of one section HawkZ28 Remodeling 4 02-20-2009 03:33 PM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 06:16 AM
