How to run ducts in walls...
You cut a hole down the length of the drywall, then either use Duct board to create the duct in the cavity, or build out the wall to allow the 6" or 8" duct the room that it needs. Keep in mind, if you are feeding multiple rooms with this feed, you are going to need more than one 16" by 4" space for the volume needed to feed all of them.
Then there is the issue of distribution to those rooms, so that means cutting into the ceiling drywall to do that.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
