How To Replace Trane Compressor? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 09:51 AM   #1
How to replace Trane compressor?
Can you remove the compressor by loosening the copper line with a wrench? Or do you torch the copper lines and pull out?
Not sure if it's copper lines or aluminum?
max2k is offline   Reply With Quote
Old 07-24-2010, 10:56 AM   #2
Pair of wrenches .
Old 07-24-2010, 11:22 AM   #3
Thanks a lot for the help Marty S.
Old 07-24-2010, 04:20 PM   #4
An old Tradesmen
Rewards Points: 7,816
Hope you recover/recovered the gas first, before opening the system up.
Plus, you still need to replace/add a filter drier to the liquid line. plus, then determine what caused the old compressor to fail. You don't want to have to replace the new one in another week, or another year.
Old 07-24-2010, 04:53 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if you have to ask, the best way to remove it is use your phone to call a tech. I am guessing that is it an R22 unit and as such, there are some legal restrictions on venting the refrigerant as well as being able to obtain any to refill your unit.
Should I replace an AC compressor that works? greenmile HVAC 2 03-29-2010 05:49 AM
Possible compressor issues??? chaoskid HVAC 15 05-10-2009 02:53 PM
AirConditioning Compressor - Oil Leak? MmagicBbusS Automotive Repairs 6 04-22-2009 09:02 AM
Bad compressor, and coil question... Undepelo HVAC 24 06-13-2008 01:28 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
