How To Replace Compressor Fan Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2012, 04:09 PM   #1
How to replace compressor fan motor
I have a Goodman heat pump and the bearings froze up in the compressor's fan. I purchased a new fan, but the old one had three wires and the new has 4 (not counting frame ground).
It used to be wired with an AO motor, 3 wires:
Black - contactor on relay
Purple - "DF2" on defroster board
Brown - "FAN" on cap (3 pole, FAN, HERM, and C)
The new fan has a black, which I assume goes to black.
A Yellow - does this go to where the old purple used to go?
A Brown wire - does this go to the cap?
A Brown/White wire - just cap this off?
The new fan is a "SF Motors", model MOT13502.
Any help or insight is appreciated!
jakev383 is offline   Reply With Quote
Old 01-05-2012, 07:17 PM   #2
An old Tradesmen
Rewards Points: 7,814
Does the new motor use the same size capacitor as the old motor did?
And your wiring is right.
Old 01-05-2012, 07:44 PM   #3
Yeah, the new motor uses the same size cap as the old.
If so, then it sounds like I'm on the right track then.
And for the brown/white wire, when I say cap it off I mean put a wirenut on the end so it isn't touching anything.
Old 01-05-2012, 08:05 PM   #4
An old Tradesmen
Yep, that what I thought you meant by capping. might want to use electric tape to make sure the wire nut doesn't come off sometime down the road.
Should I replace the blower motor too? Arthas HVAC 4 05-06-2011 08:43 PM
Replace Fan Motor Maureen693 HVAC 3 04-20-2011 10:35 AM
Replace Furnace Blower Motor Jenks HVAC 1 04-24-2010 07:09 AM
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 09:57 PM
Replace a furnace blower motor dadncharge HVAC 2 12-06-2007 09:42 PM
