How To Remove This Overhead Ducting - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2013, 02:32 PM   #1
How to remove this overhead ducting
Can anyone give me a suggestion how to go about removing a section of this duct please? There's a lot of air escaping from the upper portion of this duct so I want to cap it off. I can't figure how or what tools to use to cut out the last couple of feet before it turns upward into the 1st floor. Any help would be appreciated, Steve
How to remove this overhead ducting-doc-nov-7-2013-2-03-pm-p1.jpg   How to remove this overhead ducting-doc-nov-7-2013-2-03-pm-p2.jpg
teeb57 is offline   Reply With Quote
Old 11-07-2013, 05:39 PM   #2
An old Tradesmen
Rewards Points: 6,112
The 1" wide pieces of metal on the sides of the ducts are drive cleats. Bend the top and bottom straight. Grab with a pliers and pull it straight down, may have to hit the pliers with a hammer to pull them down.
Required disconnecting means for overhead feeders? Jimboman Electrical 0 12-18-2012 07:04 PM
Plumbing, ducting, venting, roofing, who's job is whose? daluu Building & Construction 13 11-08-2012 12:44 PM
Upgrade Svc., Overhead; Bill vs. Estimate Question Rpsjr Electrical 6 04-22-2012 04:15 AM
Confused ducting in 1 story bungalow... HandyBro HVAC 1 07-16-2008 09:11 PM
Overhead lighting Run to lights first then switches, 14/3 to both switches? twilightcall Electrical 4 07-10-2008 05:18 PM
