How To Remove Gas Heater Exhaust Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 09-12-2015, 09:12 PM   #1
Rewards Points: 40
How to remove gas heater exhaust vent
I am trying to remove a gas heater exhaust/intake vent cover on an exterior wall. The reason is small birds have completely filled both ports with twigs. Twigs have been removed from the exhaust port, but the intake port is difficult to reach. I have removed the four screws, but the cover will not come off, I think because the PVC exhaust pipe has been glued directly to the cover. My plan was to locate the exhaust pipe inside the house, then cut it so that the outside vent cover could be removed. I cut a hole in the ceiling and have located the pipe. Is this the best approach to take? Thanks in advance for your help.
teejersey is offline   Reply With Quote
Old 09-12-2015, 09:23 PM   #2
Rewards Points: 34
The cover should come off after removing the 4 screws.
Search for flush mount concentric kit and you'll find images of how it's assembled.
Dan
djlandkpl is offline   Reply With Quote
Old 09-12-2015, 09:47 PM   #3
Rewards Points: 40
Dan, I found the installation instructions for the Goodman flush mount concentric kit. It says to glue the pipe to the vent cap with RTV silicone (and not to use PVC solvent cement). So if it is silicone glue, how best to remove the cap? It is a strong bond.
Old 09-12-2015, 09:59 PM   #4
Rewards Points: 40
Link to Goodman instructions (PDF)
http://www.alpinehomeair.com/related...structions.pdf
Old 09-12-2015, 10:04 PM   #5
Rewards Points: 40
Note that there is no problem with the intake pipe. It is only the exhaust pipe that is glued to the cover.
Old 09-12-2015, 10:29 PM   #6
Rewards Points: 34
RTV should pull apart with moderate force. It may have been glued which would be bad.
Dan
roof top exhaust fan vent leaking; Please help! areaman Roofing/Siding 3 12-06-2014 06:52 AM
Drill hole in conentric vent for tankless water heater? toddmanqa HVAC 7 01-09-2014 11:49 AM
Heater register vent in bathroom moving up ohman HVAC 2 09-15-2012 06:34 AM
Rheem white powder near exhaust vent? mikebau HVAC 21 03-29-2012 07:35 PM
Power Vent Water Heater Replacing Draft Vent polebarn HVAC 13 03-28-2012 06:12 PM
