How To Remove Compressor From Cooler? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 07:59 PM   #31
An old Tradesmen
Rewards Points: 7,786
Originally Posted by nicksab View Post
soap and water.but for what i have been told, my way is almost impossible because of the pressure eventually building back up or introducing air in the system??
And what about using some of that new quick connect stuff
Soap and water would require pressure to back in the line. And if you had a leak, you couldn't pump it down again.
Needs to be recovered.
Old 08-22-2011, 08:31 PM   #32
Thank you all for the advises and everything.
I will just take the top of the cooler apart so i can fit thru the door.
Doing this creates another problem to me. Since the compressor and the rest will be inside my shop, i will have an increase in noise.
How can i reduce the noise of the compressor and fan without creating any problems?
I was thinking about building a box around it and cut an opening in the wall so it will have fresh air but What about insulation??
thanks
nicksab is offline   Reply With Quote
Old 08-22-2011, 08:36 PM   #33
I'm Your Huckleberry
Rewards Points: 2,270
i am just trying to get some advise here. It is diy forum after all.
It bios the price they charge around her. If you live around san francisco i give you 100 to do It
Ha, good one!
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
nicksab (08-22-2011)
Old 08-23-2011, 05:52 AM   #34
Rewards Points: 1,216
Here's the deal Nick, hire a Refrigeration Company to remove the condenser, you and a couple buddy's move the unit into the place where it will sit permanently, have the refrigeration Company relocate the condensing unit remote IE: in the basement, on the roof, on the side of the building, on the ground on the other side of the box.
Then build a small roof over it to protect it somewhat from the weather.
Look at all the money your going to make off selling products. You have to spend to make.
COLDIRON is offline   Reply With Quote
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 01:26 PM
Removing swamp cooler control Pharmjae Electrical 3 02-10-2010 03:36 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 09:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 10:45 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 04:12 PM
