How To Remove The Blower So That I Can Oil It. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 10:02 AM   #1
How to remove the blower so that I can oil it.
I have a comfortmaker gas furnace, Model G-11 400050-08M, the year is 1980. It says to remove the blower and oil in the front and back. It appears that it will slide part of the way out. Do I need to remove any of the wiring harness or wiring?
Just Joan is offline   Reply With Quote
Old 01-09-2012, 11:41 AM   #2
how
Rewards Points: 1,104
It should be able to just be oiled without it's complete removal.
Can you see the oil port on the visable part of the motor? You may have to remove an oil plug. It is usually on the top edge of the motor or in a slight depression on its end. It will also have a matching oil port in the same position on the other end of the motor inside the fan cage. Turn off the power to the furnace and you can each in to feel it. If that has an oil plug in place, you can remove it with needlenose plyers. You then need to bend the tip of a zoom oiler 90 degrees to reach it. Non detergent oil only.
Probably best to send us a picture first of what is visable of the motor.
Some replacement direct drive motors from mexico have only one oil port.
how is offline   Reply With Quote
Old 01-09-2012, 12:23 PM   #3
Non detergent oil only. [IMG]file:///C:/DOCUME%7E1/John/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG]
hvac5646 is offline   Reply With Quote
Old 01-09-2012, 06:36 PM   #4
REP
I don't know where you are or what stores you have near you.
If you can't find Non-Detergent motor oil easily,most places have what is called 3in1 oil which is non-detergent.
Or maybe you could borrow a 1/2 oz from a garage in 20 weight.
REP is offline   Reply With Quote
Old 01-09-2012, 07:01 PM   #5
Only Three in One Motor oil is non detergent. The regular Three in One brand is not.
Old 01-09-2012, 07:15 PM   #6
Rewards Points: 14,026
Any auto parts store, Wal Mart, even the Dollar store will have straight 30 wt. oil.
Old 01-09-2012, 07:21 PM   #7
biggles's Avatar
if the motor is inside the squirrel cage then just the one end can be oiled might see little yellow plugs at the motor end should slide out like an overn rack
Old 01-09-2012, 07:22 PM   #8
Rewards Points: 582
you don't have to remove blower assy all the way out to oil...use non detergent with long flexable spout...
Old 01-09-2012, 10:25 PM   #9
Rewards Points: 38
red can 3 in 1 oil in not to be used on motor bearings. it contains naptha. the other (green can i think) is labled for motor bearings.
If using automotive motor (really engine oil) it must be non-detergent. it will be labled ND 30. all other automotive oils are high detergent which are not to be used. (hd 30, 10w-30, 0w-50, etc)
if detergent oil is used it will eat the bearing, if used i would flush them with plenty of 30 nd.
bernie
ps straight weight oil comes in both ND and HD. only use ND.
bernie963 is offline   Reply With Quote
Old 01-10-2012, 06:49 AM   #10
Rewards Points: 1,668
The 3-in-1 for motors is in a blue can.
bob22 is offline   Reply With Quote
Old 01-10-2012, 08:17 AM   #11
Rewards Points: 38
at least i knew it wasn't a red can!!!!
some how green didn't seem right, hence the ? mark. just another senior moment!!! one more of many!!!!
bernie
Old 01-10-2012, 08:20 AM   #12
Hopefully they haven't changed the color. My shampoo brand keeps changing the color and graphics between my purchases and I'm never sure I'm buying the same stuff; the little things in life!
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Comfortmaker RPJ II Enviro Plus 90 Flame stops with main blower starts hansolos HVAC 1 10-30-2010 11:35 AM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 04:13 PM
RPJ2 Blower fan will not stop running number22 HVAC 8 07-19-2009 05:27 PM
