How To Remove Ac Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2012, 11:33 AM   #1
how to remove ac unit?
hi...
tried to search for this and couldn't find much...
anyway, i'm building a patio in my backyard and i need to get rid of this 40yr old ac unit... the new one will obviously be placed somewhere else, but how do i remove this one and its cables/wires? can i just turn off the power and just cut the cables/hoses?
also, can i throw this unit right into a dumpster or do i have to call someone?
thanks.
danxp is offline   Reply With Quote
Old 05-17-2012, 11:41 AM   #2
biggles's Avatar
have a HVAC company reclaim the freon..keep that paper work filed then cut it up...if your not going for a new unit relocated...go into your CB panel and remove the breaker that feeds that disconnect....junk guys would love that condenser and do it for you freeeee
Old 05-17-2012, 11:45 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Does it have refrigerant in it? That'd be the main concern.
That electrical disconnect you can simply pull out or turn off if it's a breaker. Check the voltage regarldess once it's off as you never know.. Use a meter to check for voltage at the contactor or push in the contactor which is inside of the elctrical service panel of the unit (use a rubber handled screwdriver or something rubber handled, never your fingers).
From there you can simply cut the wires, even the small control wires but if the condenser is still connected to the inside unit and stat then turn the BREAKER to the inside unit off first as well, especially if you plan on re-using the inside unit.
Other than that, the refrigerant is a concern. You can't legally handle refrigerant without an EPA license and I doubt you have a recovery machine and tank or refrigerant gauges.
If the condenser is running and you have some allen wrneches than you can "pump the system down" meaning close of the high side service valve of the condenser which will trap all of the refrigerant in the compressor. You'd need gauges to know when that refrigerant is removed from the lines and trapped in the compressor. You close off the low side service vale once the refrigerant is in the compressor to hold it there. Btw, this all happens with the condenser running so you'll need power to it to pump it down. From there you use tubing cutters to cut the copper lines. If you don't have tubing cutters a hack saw will work or a saw zawll with a metal cutting blade. Do not use the same lineset if you cut it with a hacksaw or electric saw. Too many metal splinters will be left in there, cause for a major catastrophe for the new system.
Tubing cutters are cheap from The Home Depot or anywhere.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-17-2012, 11:46 AM   #4
Yup, that's about $100 worth of scrap metal down here.
Thanks.
Old 05-17-2012, 12:14 PM   #5
know of any companies in the north jersey area that would be willing to take it?
Old 05-17-2012, 01:48 PM   #6
biggles's Avatar
too old just get the freon done and hacksaw the lines back..might want to keep that concrete pad for a step off from that new patio.any HVAC guy is licensed and bump into one localluy and throw them $$ they will do it while sipping a beer in your drive way...there is what tops 5lbs if the air handler is in the basement more if up in the attic.if your thinking of a new system check out PSE&G up there..for a credit for older units updating stuff...never know but you would have to be doing an upgrade to get some money off..they have contractors that do their work...check it out
Old 06-28-2012, 10:35 AM   #7
my hvac guy reclaimed the refrigerant properly and disconnected the lines... it's now ready to be taken away by scrap metal guys...
Old 06-28-2012, 12:16 PM   #8
Rewards Points: 242
if you put that unit by the curb. someone will take it before you get to the house.
hvac instructor is offline   Reply With Quote
Old 06-28-2012, 03:43 PM   #9
An old Tradesmen
Rewards Points: 7,816
LOL, could get mugged for it on the way to the curb.
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
AC Window Unit Size, 10k or 12k? Tuksonrider HVAC 7 06-17-2010 11:35 PM
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 09:51 AM
AC condensing unit failure? Hotinsummer HVAC 3 08-09-2009 02:08 PM
Need to remove old central air unit pmb003 HVAC 4 05-03-2006 04:05 PM
