I recently had to replace both of my carrier AC's control boards. They were damaged during a thunderstorm/lightning. I was wondering if anyone has suggestion about how to protect AC control board from thunderstorm/lightning.
And if you live in Florida or the Ozarks you've got real problems with lightning.
Single board protectors are probably cheaper than whole house protection and are better tailored to the application; you might want to ask the HVAC manuf. Sometimes a single MOV in the right place is enough.
Some manuf. will send you the part for free, just for asking.
I sell a lot of UV lights, and Florida is one of my most difficult areas to deal with. It also, by the nature of its humidity is where I send the most units.
I always try to first encourage HO to chose models that have 120 volt power supplies. These are sturdier and are able to help protect the bulb against spikes. Next, if the light has to be 24 volt, I encourage them to choose an extended range light (one that can withstand up to 32 volts of surge) and if possible, to add an additional 24 volt transformer to power the lamps power supply.
I do know that in most areas of Florida, the power companies offer a monthly fee for adding a surge protector before the power enters the home. This may be available in other areas of the country as well, i just have never asked.
On my furnace/ac system, rather than being hard wired to 120 volts somebody wired it to a heavy duty cord and plug! Its then plugged into a single circuit receptacle.
If I had a problem of this nature (which I don't) I would buy a typical surge protector, plug it into the receptacle and plug the furn/ac into this!
An outdoor A/C condensor uses 220 volts and a surge protector would have to be rated for 30-40 amps continuos duty which eliminates the standard plug in type. The whole house type sounds good as refrigerators etc could use protection also.
I have no electronics in the condensor. Just a contactor that is operated from 24 volts in the furnace.
All the electronics are operated from 120 volts.
Compressors get damaged A LOT from power surges so both voltages need protection. Most new units use a single pole contactor so there is a hot supply thru to the capacitor and compressor even when the contactor is open. A good surge can potentially blow thru the windings to the metal case of the compressor and blow it. Not sure how much protection the whole house unit can provide from a large direct strike but it may help.
Thanks for all the info and discussion. Not sure which path I will follow though.
Does any home owner have experience with any of these device ... price/performance ??
>> a whole house protector is the way to go. About $200.00 for a Leviton.
This one seems to be too involved. I might need to work with electricity company to get permit etc..:wallbash:
$200 is justified if you had a >10% chance of zapping $2000 worth of equipment. The $200 is like the premium for an insurance policy.
If the chance is >20% you should spend $400 to protect the $2k of equipment.
I've never had one and I've never gotten my stuff zapped, but I don't live in Florida or the Ozarks, which are hot spots for lightning strikes.
What are the odds that your control board damage was a fluke [or the beginning of a trend]?
I contaced my local power supply company and representative stated that they do have the lightning protection at the transformer. He says surge could come into house through cable/phone line and into electrical lines of the house (through appliance which are connected to cable/phone and electrical lines). Now if you were to believe this theory then this adds more confusion to the problem.
Thanks. It's a good read. It has a nice 'Isoceraunic map of US'. I live in a region with isocenauric level of 40.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
