Old 03-13-2008, 01:13 AM   #1
How to protect 3/4" copper pipe passing through concrete
I have a split level and need to drill through concrete for a 3/4" copper pipe from my boiler to some baseboard radiation. Any recommendations for the hole size, and what to line it with so that the heat-up/cool-down expansion and contraction doesn't wear my pipe?
Thanks,
Mike
Mike Warner is offline   Reply With Quote
Old 03-13-2008, 01:25 AM   #2
ICF Construction
Core a 1 3/4" hole and insert a piece of 1 1/4" ABS then feed your copper through. seal the ABS to concrete with hydralic cement, seal the copper to ABS is some low expansion foam.
Chris
Chris Johnson is offline   Reply With Quote
Old 03-13-2008, 01:37 AM   #3
Thanks Chris, much appreciated.
Mike
Old preasure valve, new copper pipe. fast380 Plumbing 5 01-12-2008 11:36 PM
Sewer pipe under concrete driveway marejw Plumbing 7 12-22-2007 05:19 PM
Can I Extend the 3/4" Copper Pipe? froddan Plumbing 2 07-23-2007 05:03 PM
Cap Off Copper Pipe Jareb Plumbing 3 06-22-2007 10:43 AM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
