How Old Is This Heater. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-23-2011, 12:48 PM   #1
How old is this heater.
Lennox heater, can we find out how old this heater is. GT3-50W-E thats all I can see. The E could be an F
Thank you
Briggsey is offline   Reply With Quote
Old 09-23-2011, 03:53 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Serial numbers will typically tell you. numbers 3 & 4 of the serial are the year. Example : 5891G.... Unit built in 1991
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-23-2011, 04:59 PM   #3
This is a model # then- any idea when built? Lennox tag does not have serial # on it.
Old 09-23-2011, 07:18 PM   #4
the -50W makes me wonder if you're looking at an evap coil. Nothing on the Lennox data site matches those numbers.
Old 09-23-2011, 11:16 PM   #5
It was on a metal rectangle tag. With Lennox gas heating equipment on it. Top and bottom is teal with a drawing of a man/boy that looks like it comes from the late 40's/50's. It was at the bottom of the heater and has on it "TO LIGHT THE APPLIANCE" & "TO TURN OFF THE APPLIANCE" ON IT. I'll look some more. Mainly just curious. House is from 1925. I have to replace it. Heat exchanger has a crack. Heater guy says it could start leaking carbon monoxide into the house. Not a tight house but don't want to take any chances. Thanks for info.
Old 09-24-2011, 12:30 PM   #6
Pilot, yea that thing is pretty old. more than 20 years for sure. could be 30-40. If there is a crack, don't run that thing. replace it.
Mr.HVAC is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
