Old 07-31-2010, 12:23 PM   #1
the Musigician
DangerMouse's Avatar
How much space between furnace and walls?
Is there code on this? I imagine there is... Po)
Thanks guys!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-31-2010, 12:34 PM   #2
Hvac Pro
Is it gas or electric unit? The rating plate will have the specs for clearances to combustibles or the install manual which may be online.
Old 07-31-2010, 12:38 PM   #3
Master HVAC Technician
Yuri has it right. The unit should be marked with "clearance to combustible surface" information. Generally oil furnaces have a larger clearance requirement. Special units like some 90% and higher gas units and mobile home furnaces may be rated for 0 clearance, meaning it can be installed with full contact. Clearance requirements may also come into play with the type of floor its on as well, requiring a non-combustible base kit. Check the plate and the manual. Don't take chances.
Rusty999 is offline   Reply With Quote
Old 07-31-2010, 12:44 PM   #4
the Musigician
It's a mobile home unit that HAD about a 2" gap around it. I was thinking if I ever get a larger unit, I may want more space in the hole as well?
DM
Old 07-31-2010, 01:00 PM   #5
Hvac Pro
Check out the Nordyne/Miller/Intertherm site. They make a lot of mobile home units, cornered the market where I am. You don't want to lose clearances for fire insurance reasons.
Old 07-31-2010, 01:07 PM   #6
the Musigician
Well, it was installed by a company so I imagine the 2" was OK then? I was thinking more like 3", so I should be safe enough. My concern is the size of the newer units. Will they fit in the same area if/when I get a higher eff. rated one? It's being reinstalled on 3/4" ply floor over 2x12s, centered on 16". The flange I removed will slide nicely between the joists, but I'll need a plenum to attach the steel ductwork I'm using to, below the level of the joists..
....and dampers, and register vents, and elbows, etc...
DM
Old 07-31-2010, 01:52 PM   #7
Hvac Pro
W/O knowing the model and manuf. specs we cannot answer that. Beware that mobile homes have skinny undersized ductwork so you may need to upsize it for a bigger unit. Try Nordyne and see if they have online install specs for those units.
Old 07-31-2010, 02:03 PM   #8
the Musigician
This thing kicks out some major heat, and I'm using 6" round ducts traveling only a bit farther than the flat ones were.
The inspector said it matters not, as long as it can maintain 68° at 3' from the floor. It's a 62,000 btu Nordyne direct vent/forced air unit.
DM
Old 07-31-2010, 02:04 PM   #9
the Musigician
propane
DM
crawl space venting and HE furnace? bcbud3 Remodeling 10 03-09-2010 04:33 PM
Filling basement cinder block for insulation. diy4life Building & Construction 8 11-25-2009 04:33 PM
Make up ventilation through return on furnace question creamaster HVAC 8 09-27-2009 05:53 PM
Building walls around a furnace amazinlittledevil HVAC 19 07-31-2007 04:01 PM
closing vents in unused living space scottydel HVAC 1 12-05-2006 02:39 PM
