Old 07-16-2011, 03:28 AM   #1
How much savings by raising thermostat?
I have the thermostat set at 79 degrees in the summer when I run the air conditioning. What percent savings be achieved by raising the thermostat by two or three degrees to 81 or 82? I live in Arizona so humidity isn't a factor. My A/C unit is 5 ton, built in 1995, but has only had 11 years of use since first owner of house was never present in summer. I don't know what specific number insulation the house has, but it's the blow-in type in the attic vs thick pads. I don't change the thermostat, but rather leave leave it at a set temperature.
AZSun is offline   Reply With Quote
Old 07-16-2011, 08:45 AM   #2
An old Tradesmen
About a 2% savings for every degree you raise it.
Old 07-16-2011, 11:00 AM   #3
JJboy's Avatar
You already have the thermostat set to save with that temperature. Increasing the temperature it will compromising your comfort.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-17-2011, 12:10 AM   #4
I know, but I'm willing to sacrifice some comfort in order to save money. I'll just use more fans.
Old 07-17-2011, 09:05 AM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
You are not going to save money using room fans. I would shop around for a better electric supplier if you can, but where you have the thermostat now, is in line with EPA Energy savings guidelines.
Old 07-17-2011, 12:33 PM   #6
Do you not have ceiling fans? Adding extra fans to my home wouldn't serve any purpose since every room has a ceiling fan I can use.
Mrdippy is offline   Reply With Quote
Old 07-17-2011, 02:14 PM   #7
An old Tradesmen
Ceiling fans use a lot of electric when you have several running at a time. The A/C can end up being cheaper to use at a slightly lower set temp.
Old 07-17-2011, 03:09 PM   #8
I have three ceiling fans in my house and if I read that a 52" ceiling fan uses 90 watts at high speed. So if I have all three on high that's 270 watts vs 3500 watts for a 5 ton A/C. I don't understand how there is no savings by raising an a/c thermostat.
Old 07-17-2011, 03:15 PM   #9
An old Tradesmen
Those 3 fans generate almost 1,000 BTUs of heat, so your A/C also has to remove that heat.
Check the actual wattage of the fans and the A/C.
Old 07-17-2011, 05:38 PM   #10
Good points folks! I keep my ceiling fans on low just to keep air mixing... I believe a ceiling fan on low would be mixing an entire room using less power than a common portable fan. HIGH on a ceiling fan is probably only a good idea when you have no AC....
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
