Old 03-27-2012, 05:31 PM   #1
How much does it cost to convert...
How much would it cost to convert an oil water heater to an electric water heater?
LuluQuinones is offline   Reply With Quote
Old 03-27-2012, 06:20 PM   #2
An old Tradesmen
Look at electric water heaters at HD and Lowes, along with the wire and breakers and electrical disconnect you would need.
There is no conversion kit to change your water heater over to an electric unit.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-27-2012)
Old 03-28-2012, 07:05 PM   #3
sktn77a's Avatar
You need to run 220v to the heater and an electrical service that can support this. I believe most local codes require a licensed electrician to do this.
sktn77a is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 63 12-17-2012 10:29 PM
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 11:20 AM
How much does a square foot of housing cost in Albuquerque, NM? spook4563 Building & Construction 2 02-28-2011 04:04 PM
Cost Plus Contract coachgns Building & Construction 9 02-10-2011 11:30 AM
convert wood fireplace to gas fireplace brisk Building & Construction 3 06-19-2008 09:17 AM
