How Much Does A 5 Ton Air Handler Weigh? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2008, 06:12 PM   #1
How much does a 5 ton air handler weigh?
I am curious at the air handler's weight. Also, how many amps does a 5 ton air handler use? Thanks.
737Pilot is offline   Reply With Quote
Old 09-09-2008, 06:40 PM   #2
um...wouldn't it weigh 5 tons?
leafyme is offline   Reply With Quote
Old 09-09-2008, 08:48 PM   #3
electrical contractor
Rewards Points: 150
does it have a gas furnace or electric heat strips? single speed fan or variable speed? Make/ Model? Give us more info and we can help you.
Jimmy
Life is tough, Life is tougher when you are stupid.
Last edited by wire_twister; 09-09-2008 at 08:49 PM. Reason: spelling, or lack thereof
wire_twister is offline   Reply With Quote
Old 09-09-2008, 10:46 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
as wire twister stated, there are a lot of variables. If it is only an air handler, there are still a lot of variables.
simply put, there is really no way to tell. What type and size of motor, what size the cabinet is, what type of coil is in it. Just too many possibilities.
Old 09-10-2008, 09:01 AM   #5
I have no idea yet as I don't have a unit. I was just curious. Any ball park guess for an average weight? 120 lbs? 150 lbs? 250 lbs??
Old 09-10-2008, 10:39 PM   #6
Rewards Points: 150
I have a Carrier 5 ton system with a 98% furnace, with a variable speed fan. This unit weighs about 240 to 250 pounds, sorta tough to get up a ladder and into the attic.
Jimmy
Old 09-11-2008, 10:05 AM   #7
nap
You talking to me?
nap's Avatar
So, now that that is out of the way;
How much wood would a woodchuck chuck if a woodchuck could chuck wood?
Old 09-11-2008, 08:50 PM   #8
Idiot Emeritus
Rewards Points: 1,492
Simple....A Woodchuck would chuck all the wood that a woodchuck could!
I don't think I've heard that one since the kids were little. Brings back very fond memories.
Rob
micromind is offline   Reply With Quote
Old 09-11-2008, 09:08 PM   #9
nap
You talking to me?
nap's Avatar
the way I heard it was:
a woodchuck would chuck all the wood a woodchuck could chuck if a woodchuck could chuck wood.
it is also the answer to the original question as well.
(you didn't think I was posting it just for the nolstagia did you?)
an air handler weighs what it does. Nothing more, nothing less but what it weighs cannot be determined without knowing.....well......what it weighs. There is no true answer to the original question.
DIY Heat Pump/Air Handler replacement hennyh HVAC 62 06-18-2012 06:11 PM
Air Handler Fan Sporadic Sammy HVAC 5 05-18-2008 06:30 PM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 09:14 PM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 09:23 AM
Drainage from air handler jack B HVAC 1 05-07-2006 09:35 AM
