How Much Difference Does Furnace Size Make - HVAC - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 09:45 AM   #1
how much difference does furnace size make
I have 4 different contractors and 4 different answers.
How much difference is there if I choose a 70000 btu or a 90000 btu?
I already threw out the high (100000) and the low (60000).
chaley is offline   Reply With Quote
Old 09-03-2010, 11:02 AM   #2
The size should be based on a heat loss calc
Insulation, windows, your location all have an effect on sizing
Old 09-03-2010, 07:33 PM   #3
An old Tradesmen
Rewards Points: 7,278
You can do your own load calc. http://hvaccomputer.com/talkref.asp well worth the 49 bucks to use it.
The 60,000 may indeed have been the right size.
An oversized furnace on undersized duct work. means higher then needed heating bills. And possible service problems, keeping it running.
Old 09-03-2010, 08:29 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
An oversized furnace will have chronic overheating problems/run too hot/ride the limit control and will have an expensive premature heat exchanger failure.
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Furnace and possibly AC recommendations MzzGriz HVAC 16 08-09-2010 09:00 PM
How to size a replacement gas furnace B4Dark HVAC 10 06-10-2010 09:55 PM
furnace size? dr? HVAC 32 01-21-2009 07:36 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
