Old 10-08-2010, 12:28 PM   #1
Sephora's Avatar
How many years do you need to replace a Hot Water Heater?
Just curious...ours is heated via gas furnace.
Sephora is offline   Reply With Quote
Old 10-08-2010, 01:12 PM   #2
I can usually replace them in about an hour or so.
OH! You meant, how long will a water heater last?
Well, it depends. I replace them when:
The water heater starts leaking.
OR
The water heater doesn't heat water anymore.
Depending on the quality of your unit and the water in your home, that can be from about 5 to 20 years.
moondawg is offline   Reply With Quote
Should I replace my blue board after it got wet from a water heater leak? petep Drywall & Plaster 4 07-11-2010 10:44 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Hot water heater - Should we replace it?? liberty610 Plumbing 26 12-13-2009 12:23 AM
Installing a Tankless Water Heater infoiam Plumbing 4 11-10-2008 10:59 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
