Old 08-11-2008, 07:23 AM   #1
How many wires do I need for my Thermostat?
How do I know if I need a 5 wire or 7 wire spool of wire for my Thermostat to my units? I am setting up my central heat and air. Everything is run but the t-stat wire. My t-stat manual just shows how to hook it up. ANy info would be appreciated.
twilightcall is offline   Reply With Quote
Old 08-11-2008, 09:25 AM   #2
RippySkippy's Avatar
Check the manual for the device on the other end, you might get closer, usually the t-stat will only tell you which wire goes to which terminal. You've left out a bunch of details...like the type of system do you have, is your AC a single or dual stage unit? Do you have a boiler?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 08-11-2008, 11:28 AM   #3
You are better off to run a 6- 8 conductor dependant upon how many stages of heat and cooling you have. Maybe even use them for a humidifier if you need. Even if you have too many wires, you can just leave them disconnected behind the tstat and use them in the future if one of your wires has a break.
statman is offline   Reply With Quote
Old 08-11-2008, 01:59 PM   #4
Thanks for the info. I have a 2 ton Lenox unit with heat pump and auxillary heating strips when the temp gets colder than a certain temp. No boiler or humidifier.
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 HVAC 4 06-02-2008 04:44 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 12:52 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
