How Many Tons Of Cooling In My NJ Home? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 07:32 PM   #1
Rewards Points: 150
how many tons of cooling in my NJ home?
Yes yes, i know. I'll get a hvac load calc , but just looking for guesstamits!
1950s ranch, 1000 sq ft main level, and basement that is getting finished which is 85% Below Grade.
OLD single pane wooden windows, MAYBE an r-11 in the walls ( 2" thick or so....if that " maybe 3" of insulation in the attic that is falling apart.
Summer temps can reach 100+ degrees, typically in the 80s-90s all summer long here in central NJ, humidty can get very very high.
I had a buddy reccomend to me that I go with a 3 ton unit? Though... Alot of the " rule of thumbs " i see are 500 sq ft per ton.... so that works out as:
2 tons per main level
go half a ton for the basement since below grade ?
or
give the basement 1 ton?
Should i just assume 3 ton to be safe with my old ineffectient drafty home?
THanks
alecmcmahon is offline   Reply With Quote
Old 04-26-2011, 07:43 PM   #2
An old Tradesmen
Rewards Points: 7,304
Why look for a guesstimate from people that can't even see your house. When you can do your own for 49 bucks, and know for sure.
http://hvaccomputer.com/talkref.asp
Old 04-26-2011, 07:49 PM   #3
Rewards Points: 150
I have an older mac computer, none of the programs are compatible.
Old 04-26-2011, 07:56 PM   #4
An old Tradesmen
Wal Mart has a special on PCs.
Sorry, just jerking your chain.
No good guesses can be made over the internet.
Old 04-26-2011, 07:56 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
A very rough rule of thumb is about 1 ton per 500 square feet. Lot of other factors come to play mind you. I would get the installer to do a load calc of course, but if you're shopping I'd just look at 2-4 ton units just to see the prices, don't buy anything till a true calc is done.
Old 04-26-2011, 07:59 PM   #6
Rewards Points: 150
I figure that... 500 sq ft per ton is for a drafty old house right?
Should a 80% below grade basement that is rougly 1000 sq ft be counted as 500/500 = 2 tons... or since it's below grade only one ton? or half ? what is the GENERAL rule of thumb with that?
Old 04-26-2011, 11:54 PM   #7
Rewards Points: 150
Success! Found my girlfriends old PC laptop, i downloaded the HVAC-CALC 4.0 software and enterened in alll my information.
Im just waiting for the registration code email so that it'll actually display my results, went and paid the 50 bucks, the program seems to work pretty good actually.
Old 04-27-2011, 04:19 AM   #8
An old Tradesmen
Its a pretty easy program to use. Don't fudge the numbers and enter "safe" temps or insulation values. You'll be surprized how much A/C you don't need.
Old 04-27-2011, 06:31 AM   #9
Insulation is cheap,less then $300 for our house which is the same size. Bet a ton and a half will be close if you put R45+ in the attic and caulked those air leaks.
Old 04-27-2011, 09:10 AM   #10
Rewards Points: 150
Got my report!
2.5 tons, it was 2 tons before I added my porch that we never used cause it was always too damn hot. So 2.5 tons should suffice now.
for those on the fence about purchasing this program, just go for it. Def. worth the 50 bucks.
The Following User Says Thank You to alecmcmahon For This Useful Post:
operagost (04-27-2011)
Old 04-27-2011, 07:54 PM   #11
An old Tradesmen
You fudged the summer outdoor design temp. You'll end up with high humidity.
Old 04-28-2011, 12:42 AM   #12
Rewards Points: 150
I realized that and corrected back to defaults. Puts me lil bit below 2.5 tons.
But, today I spoke to my neighbor who has the same house as me, same age. Same layout, same sun. He has 2.5 ton unit and said the unit def has a hard time making temputure in the summer. He had it pro installed 5-7 years ago and serviced last year. He said he'd go 3 ton next time around. Just something I should consider I suppuse
Old 04-28-2011, 04:26 AM   #13
An old Tradesmen
Probably more like his duct work is under sized, then his unit. My own will run for 6 hours non stop when we have our 98° days here, then shut off for 10 minutes or so, and then run for another 4 to 6 hours.
On the hot days, an A/C should run for long long periods of time.
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 08:15 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Home Addition destepan Building & Construction 6 12-05-2007 12:28 PM
only 3 Tons for 3700 Sf Ft? 1K2GO HVAC 7 11-23-2007 06:13 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
