How Many Return Vents Needed? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2008, 12:07 PM   #1
Rewards Points: 324
How many return vents needed?
Im working on finishing my basement, currently working on the HVAC ducts. How do I determine how many return vents are needed? Does it just equal the number/size of supply vents?
(still waiting to hear back from City on these questions. So far they are not very helpful or responsive)
tigerbalm2424 is offline   Reply With Quote
Old 01-02-2008, 01:47 PM   #2
hey tiger im also trying to run my own ducts, so as far as i know and have read you have to match or better surpass the amount of cfm you are supplying so the furnace doeesnt have to work harder to get the air. hope the other guys can help you out
qnzkrew is offline   Reply With Quote
Old 01-02-2008, 02:00 PM   #3
Rewards Points: 324
Yeah, thats what I just read too.
Old 01-02-2008, 02:28 PM   #4
are you doin the whole ductwork layout yourself?
Old 01-03-2008, 12:04 AM   #5
Union HVAC Tech.
The return should be double the cfm size of the total of supplies to cut the velocity in half.
bigMikeB is offline   Reply With Quote
Old 01-04-2008, 09:35 PM   #6
duct
where i come from they tell us 20% larger on the return side is sufficient.
5kimprovements is offline   Reply With Quote
Old 01-05-2008, 08:10 AM   #7
Union HVAC Tech.
Wouldn't you say that a typical residential supply trunk is 24x8 and a typical return is 25x16?
Old 01-05-2008, 08:25 AM   #8
biggles's Avatar
if you had the unit just the other side of the wall in the basement and in a closet the return ducted or not out to that wall along the floor with a grill on the finished side is typical.keep the filter size in mind when extending it or just open the wall and size the hole the size of the fiter.you don't need the return to run the lenght of your supply ducts just nearest the unit and the stat location.
Old 01-05-2008, 09:56 AM   #9
Not too sure what the answer is. Perhaps the answer is between 20% - 50% "more" intake volume openings when compared to heat vents. Not too sure. If you can, target 50% more. If needed, you can always block off the intake vents you feel your basement doesn't need.
I do know that our basement's floor was always cool. Too cool. After our basement flood in 2005, a furnace guy installed 2 cold air intakes that now "suck air" off our basement floor. Since then, our basement floor and rooms have felt much warmer. When installing cold air intake vents, do ensure their vents are at bottom of basement floor. Their location dramatically helps...
Spike99 is offline   Reply With Quote
Old 01-05-2008, 11:10 AM   #10
biggles's Avatar
just like in commercial HVAC we use the return to move some air back to the unit with the return pull(inthe false ceiling by adding return grill work),,so the discharge heat is supplied into th basement and the unit pulls the remaining heat acrossand into the cooler floor...you will know the return is good when you go to open the fan section with the unit running...should pop up and out easily
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
