How Many Millivolts For This Thermocouple? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 01:26 PM   #1
Rewards Points: 682
How many millivolts for this thermocouple?
My fireplace pilot light won't start. An appliance store tested the thermocouple and said it was okay.
Should this thermocouple put out between 18-30 millivolts when in the lighting flame? There is a tiny bit of exposed wire, could this have ground out the thermocouple? I want to check everything before pulling the gas valve.
darsunt is offline   Reply With Quote
Old 12-02-2013, 05:32 PM   #2
An old Tradesmen
Rewards Points: 7,414
Do you have a thermocouple, or a thermopile/powerpile.
Thermocouple, 25 to 30, powerpile 500 plus mV.
Thermocouple has no wires, thermopile has 2 wires.
Old 12-02-2013, 06:52 PM   #3
Rewards Points: 682
It has 2 wires. So must be a thermopile? Thanks
How much does a thermopile usually cost? And why use a thermopile over a thermocouple?
Old 12-02-2013, 08:32 PM   #4
Plumber & Gasfitter
Rewards Points: 77
Thermocouples circuit powers a pilot coil, thermopiles circuit runs the pilot coil, main gas coil, and pass power thru wall switch, door switch, high limit and anything else required.
joeplumber85 is offline   Reply With Quote
Old 12-02-2013, 10:36 PM   #5
An old Tradesmen
40 bucks, give or take a few dollars.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Need help with thermocouple replacement on MC furnace YerDugliness HVAC 8 01-13-2012 07:24 PM
Thermocouple nut problem w/ gas fireplace movick724 Appliances 1 11-08-2011 03:00 AM
Thermocouple and Gas Valve dimjim HVAC 10 03-22-2011 10:05 PM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
