How Many Amps For My New HVAX Set Up. - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 12:18 AM   #1
How many amps for my new HVAX set up.
My HVAC setup is a furnace, fan, and Central AC compressor. The blower/fan works for both. There is another fan the other for the furnaces chimney.
The origianl 40 year old unit was a two in one, it did both AC and heat was inefficent and blew the breaker every now and then. Thankfully this does not happen with my new unit.
The new unit feeds back to my subpanel on 30amp two phase breakers. This is the original breaker setup since that was what the old one was on. Is there any chance my new system belongs on something less like a 25amp.
It is a Rheen, 1.5 ton A/C and the blower/fan is enough for 900 Square feet?
I am asking because I want to change my panel but can not upgrade my service from the meter and I need to see if I can save on some amps in the panel somewhere?
How would I calculate this?
What info ins needed?
Jzone99 is offline   Reply With Quote
Old 08-24-2012, 02:31 AM   #2
Rewards Points: 614
it will say on the name plate of the condensig unit 1-1/2 ton i a suspecting a double pole 15
carmon is offline   Reply With Quote
Old 08-24-2012, 11:17 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Thats single phase,not 2 phase.
Anyway I figure 125% of what the name plate on unit says the LRA are,or if it gives a maximum breaker size go with that.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 08-24-2012, 05:15 PM   #4
An old Tradesmen
Rewards Points: 6,088
Do you mean LRA, or do you really mean RLA?
Old 08-24-2012, 06:39 PM   #5
plummen's Avatar
Locked rotor amps is what I meant,not load rated.
Old brain does weird things early in the morning some days.
Old 08-24-2012, 07:45 PM   #6
An old Tradesmen
I think you mean Rated Load Amps. As Locked Rotor Amp could be 68 amps on a 1.5 ton compressor. But RLA may only be 14.
How can I check that a house cct can deliver 15 amps psommerfeld Electrical 26 12-03-2011 11:58 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
