How To Make Takeoff On Flex Supply Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2010, 12:50 PM   #1
how to make takeoff on flex supply duct
installing new 16" flex in crawl space and want to know best way to make 6" taps for branches to registers? Do they make a metal Y fitting?
Any help would be appreciated.
jimmy anderson is offline   Reply With Quote
Old 07-18-2010, 06:24 PM   #2
I'd hook the flex up to insulated tin duct an run the take offs from there.
Old 07-18-2010, 07:23 PM   #3
An old Tradesmen
Rewards Points: 7,318
Yes, they make wye's that you can use. The wyes will be sheet metal.
16" flex. Guessing your installing a 2.5 ton unit. if its only one trunk line.
PS: Flex in a crawlspace, should not be close to the crawl's floor. Mice/rats like to eat it.
Old 07-19-2010, 05:56 AM   #4
Rewards Points: 280
Available from Lowes off the shelf or by special order.
http://www.standexadp.com/catstyle.p...groupname=Wyes
Another site.
http://americanhvacparts.com/Merchan...e=duct-teewyes
And another.
http://www.audubonsupply.com/browse.cfm/2,335.html
One more.
http://www.theductshop.com/shop/catalog-wyes-c-1_6.html
Earnie is offline   Reply With Quote
Old 07-19-2010, 10:02 AM   #5
Flex connector
I’m a little concern on running 16” flex to supply all your distributions runs. Fist of all to your question, yes, you can buy wye’s from a distributor (don’t think box store will carry such) which he’ll probably need to order. You’d be better off taking a straight piece of metal pipe 16” dia., about 24” long and using it as a connector and then cutting in 6” saddle takeoff’s on both sides. This should be less expensive and easier to obtain. Back to my concern, your duct system should have reducers to maintain velocity and back pressure. A crude way of doing this would be to bleed off four runs and then adding a 4” reducer taking your main run down to 12”, etc. Without going through a duct design class this will give you some semblance of a normal duct system. A 16” trunk run by itself will leave your home with erratic air flow. Hope this is helpful and you are successful with your installation.
Russ Ihme is offline   Reply With Quote
Flex Duct in Soffit HooKooDooKu HVAC 2 01-18-2010 05:48 PM
Galvenized supply to PEX, How to make connection? twilightcall Plumbing 4 07-28-2008 09:28 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 08:28 PM
To Insulate or Not (Flex Duct) BasementDweller HVAC 1 07-21-2008 09:03 PM
Can I add insulation to a 6" flex duct? EE playing with HVAC HVAC 10 06-24-2008 06:07 AM
