Old 01-16-2007, 08:11 PM   #1
How to make room for humidifier
Hello all-
I am having installed a heat pump and air handler.
The present AH has the return plenum and a flexible duct inside a space in the hallway wall. It can't be backed up any. The other end of AH 'T's' into the main duct. I want to make enough space so I can put a bypass humidifier in the plenums, but the new AH is about 3.75 longer than the old. What is the best way to install this to give me room, that won't make the system less efficient? What are my options?
This is a horizontal mount, against the joists in the crawl space.
Thanks for any suggestions,
zunk
zunk is offline   Reply With Quote
Old 01-17-2007, 04:05 PM   #2
Thoroughbred Mopar Man
Hi zunk
If they are available in your area, General huimidifier makes a compact model that uses the same pad as the 1042LH bypass humidifier. If you are badly limited on space the other option would be a fan powered humidifier. Hope this helps with your problem.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-17-2007, 05:14 PM   #3
Thanks Rusty,
I have chosen to put in a Desert Springs hum., the type with the plastic rotating disks, because of my hard well water. It is 12" wide and the kind that the unit fits right into the return duct or plenum, the flex hose goes to the supply duct or plenum. My problrm is I won't have much if any room to attach it unless I modify something, and I'm not sure what to change/modify.
Thanks again,
Zunk
Old 02-24-2009, 06:00 AM   #4
An old Tradesmen
I hope he has it figured out by now.
2 Years is a long enouh time to figure it out.
My kids room is cold snmhanson HVAC 5 12-20-2006 12:51 PM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
Will my house make my kids sick??? jokrupinski General Discussion 18 09-29-2006 05:05 AM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 04:33 PM
