How Long Should A/C Take To Cool House? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-08-2007, 04:35 PM   #1
Rewards Points: 83
How long should A/C take to cool house?
I have central air in a 1650 sq ft. 2 story house. It is an old house (1930) and as such there are no returns on the 2nd story so while I know the system isn't 100% efficent, how long should it take to cool the house down to 75 degrees from 80 (outside temp. of 85).
I'm new to the house and have only turned the A/C on so far twice this summer-and each time it has taken like 2-3 hours, if not a little more, to get the house to cool down 4-5 degrees. My dad says this is fairly normal when starting A/C for the first time in awhile because you have to get rid of all the hot, stale air and after the initial long period it will balance itself out, but I just want to be sure! Is my dad right? How long should it take?
Nick
AllGoNoShow is offline   Reply With Quote
Old 06-17-2007, 06:45 PM   #2
No 100% eff. units have every been made. You have to remember that you'll only be getting about a 15 degree drop accross the evap. coil. Make sure your blower wheel is clean, filter is clean, evaporator clean, refrigerant charge dead on the manufacturers spec, condenser coil clean. Then if your house is insulated well you'll get a pretty good response from your a/c.
Call an a/c service and get it checked out. You may be able to find someone to do a thermal scan too.
Buckeyetech
Buckeyetech is offline   Reply With Quote
Old 06-17-2007, 08:01 PM   #3
Rewards Points: 6,652
2 to 3 hours is not bad to get the temp to drop at least 5 degrees. The best thing to do, is to set it for increments then when you get it comfortable to like it (ie 78 degrees), leave it there. It has been around 95 outside all day, and at 78-80 degrees, our house has been comfortable without being too cold. Of course, this is with only two 5,000 btu window units running, and a room fan circulating the air in the living area, and ceiling fans in the bedrooms.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 02:06 AM
How cool should it be inside the house? beer_geek HVAC 8 05-13-2007 02:42 PM
How do I keep my house cool without losing my view? TulipTina Remodeling 2 08-09-2006 01:42 PM
