How Long Can A Vacuum Pump Run - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2013, 06:31 PM   #16
Rewards Points: 150
Ok I should explain - My micron gauge says high pres even at 15, so I know that went bad. So I was stuck using the manifold gauges. . . But boy did I find a fix . . It only cost me 600 bucks. When I went back the next day with a new micron gauge and the "attached pic" I pulled down to "30" in less than 5 sec and down to 500 in less than 5 min. This thing freaking rocks!
Once again thanks for all the help
wetbar is offline   Reply With Quote
Old 06-30-2013, 06:37 PM   #17
An old Tradesmen
Rewards Points: 6,112
Nice kit.
Retest your micron gauge. 15" mercury, is still a positive pressure(about 1/4lb absolute).
Old 06-30-2013, 06:45 PM   #18
Rewards Points: 150
I think it was getting down to 500 and my gauges would not get there. I did go back and look and what appeard to be 15 - 18 very easily could have been 25 - 28 or so. I think it may be cheaper to get me eyes fix than fix my equipment. Because of this I am looking at going digital, but that is another post.
Old 06-30-2013, 06:47 PM   #19
An old Tradesmen
You get the right digitals, and you'll wonder why you waited so long.
Old 06-30-2013, 06:53 PM   #20
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
except for when some goof put "Magic leak sealer/ EZ fix in the system".
Splice or replace entire wire? Septic Pump bsmith6356 Electrical 5 03-18-2013 07:44 PM
Trane Heat pump - clogged filters cause failure? bigdyl HVAC 2 12-12-2012 04:27 PM
ejector pump suddenly tripping gfi lilargie Electrical 4 04-24-2012 06:15 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 11:51 AM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
