How To Layout A Cone - HVAC - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 09:47 PM   #1
Rewards Points: 636
how to layout a cone
i need to make a cone out of sheet metal. how do i figure out the radius's i need and length between and how much to cut out to get the size and slope i need. i am assuming there is formula's out there for this and was hoping to be educated
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-12-2012, 11:13 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I dont know a formula,Id practice on an old cereal box and use it for a pattern
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-13-2012, 10:01 PM   #3
Rewards Points: 960
I'm thinking a cone is a triangle, wrapped together, right?
Likewise, a cylinder is a rectangle wrapped together.
There should be a formula to tell you the circumference of a diameter or radius. Once you figure out the bottom circumference, then you'll just wrap everything over 1" uniformly and you'll have it. Just draw a line 1" or whatever parallel to one edge and overlap that much.
Are you making some caps for a school class or what?
cleveman is offline   Reply With Quote
Old 04-13-2012, 10:54 PM   #4
Ravenworks's Avatar
i got a cone calculator from goggle when I had to make a megaphone for my drag bike.
It is in Excel format but can be used with open office and super simple to use for any size.
Ravenworks is offline   Reply With Quote
Old 04-13-2012, 10:55 PM   #5
Rewards Points: 14,300
http://www.sheetmetalworld.com/sheet...in-sheet-metal
jaydevries (04-14-2012)
Old 04-13-2012, 11:12 PM   #6
plummen's Avatar
What kind of dragbike?
It dont get much easier than a banana pipe on an old z1 turbo!
Old 04-14-2012, 09:40 AM   #7
Ravenworks's Avatar
I thought I was "Old School" with my 1984 GPZ100 bored 1300
You can lay the cone out,however if it is made of metal you will have to get a sheet metal shop to "Roll It" for you
Old 04-14-2012, 10:08 PM   #8
Rewards Points: 636
thank you
Bathroom layout to fit rough in? bryanl Remodeling 6 09-21-2011 08:02 AM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 09:00 AM
Layout of Click-Lock Engineered Hardwood Layout FirstHome121 Flooring 3 04-08-2010 08:46 AM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
