How To Insulate Behind Wall Stack Supply Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 01:13 PM   #1
whirly's Avatar
How to Insulate behind Wall Stack Supply Duct
I am finishing my basement and in my area it is building code to continue the supply ducts from the ceiling down a wall. I am in the process of planning this and i have the angle boot, and rectangular stack ... but the distance between the concrete and my walls is about 4". I need to insulate behind the stack and i need at least a R14 rating ... What are the pros doing to insulate ?
FYI I am in Ontario Canada and the builders here insulate to the frost line with Pink Batt Insulation (4ft) ... I am going to be insulation the rest with Roxul ....
whirly is offline   Reply With Quote
Old 03-04-2010, 02:09 PM   #2
2" rigid foam = R10...use 2 layers
Old 03-04-2010, 03:02 PM   #3
Rewards Points: 668
Couldn't you use Roxul for that too?
Barb
gma2rjc is offline   Reply With Quote
Old 03-04-2010, 07:01 PM   #4
Old Newbie
Interesting.
Where in Ontario are you?
tinmanrob is offline   Reply With Quote
Old 03-08-2010, 09:18 AM   #5
whirly's Avatar
In London Ontario ....
I considered the rigid foam but doubling up on 2" foam plus the actual stack wont allow me the space .... Maybe i should have studded with 2x6 ...
I may have to live with the single R10 (2" foam board) behind the stack ....
It might do ...
Old 03-08-2010, 04:47 PM   #6
An old Tradesmen
Rewards Points: 7,772
Also wrap the duct with double bubble.
Running duct over bearing wall jhillman HVAC 10 03-23-2009 02:54 PM
using plastic plus insulation to insulate an interior wall Taz38 Building & Construction 8 12-29-2008 07:44 AM
To Insulate or Not (Flex Duct) BasementDweller HVAC 1 07-21-2008 09:03 PM
kitchen wall and bathroom fans sharing duct amakarevic Building & Construction 5 06-11-2008 12:13 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
