How To Install An Expansion Tank In My Hot Water Furnace? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 07:57 PM   #16
Here is a pic of my furnace. If the expansion tank is supposed to go between the PRV's and the furnace it certainly isn't there.
This I dont understand, its the cold supply line. Part goes into the furnace and part goes into the ground. what is this?
Here is a pic of my temperature setter right? set to 180 degrees
Here is a pic showing the furnace in an 'idle' state. 14psi, altimeter reads 30, temp 90degrees
I just went back down stairs and with the furnace running the temp is about 120, and pressure is 30psi
DanBress is offline   Reply With Quote
Old 01-18-2008, 05:17 PM   #17
Union HVAC Tech.
Even if ther eis one buried in the attic somewhere it has problems. Adding an extrol tank to the system could never hurt.
bigMikeB is offline   Reply With Quote
Old 10-08-2008, 04:25 PM   #18
Thanks very much for all your help. Some of the things that was suggested went over head (smile) I'll have my hubbie log in and you guys call talk man to man.
iris is offline   Reply With Quote
Old 10-08-2008, 04:57 PM   #19
Some systems used the pressure tank as the air scoop and put them at the top of the system so that any excess air would rise to the top of the system and into the pressure tank.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
