How To ID Size, Seer And Age? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-25-2013, 02:02 PM   #1
How to ID Size, Seer and age?
Can anyone help ID this unit?
Thanks!
http://[IMG]http://i829.photobucket.....jpg[/IMG]
slappydan123 is offline   Reply With Quote
Old 05-25-2013, 02:03 PM   #2
[IMG][/IMG]
Old 05-25-2013, 02:03 PM   #3
http://i829.photobucket.com/albums/z...88838FBE52.jpg
Old 05-25-2013, 02:28 PM   #4
Rewards Points: 1,192
The cat # is too blurry.
bobelectric is offline   Reply With Quote
Old 05-25-2013, 02:28 PM   #5
Rewards Points: 6,652
It is right in front of you on the label.
Old 05-25-2013, 02:42 PM   #6
Experienced HVAC Tech
HVAC1000's Avatar
Thanks!
2 ton, I think it was made in the 90s or so ( sorry it's kinda blurry), SEER looks like 10( sorry again can't quite see)
HVAC1000 is offline   Reply With Quote
Old 05-25-2013, 02:43 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
kinda looks like a 1990 24,000 BTU/2 ton York which would be a 8 or 10 SEER.
mfd date in lower right corner and 024 in model and it holds 4 lbs r22 which is normal for a 2 ton unit.
Old 05-25-2013, 03:06 PM   #8
Thanks everyone. This one might be more clear.
http://i829.photobucket.com/albums/z...8D9EE88608.jpg
Old 05-25-2013, 03:36 PM   #9
Hvac Pro
yuri's Avatar
Same as B4.....
Old 05-25-2013, 03:37 PM   #10
HVAC1000's Avatar
Very nice ya look good on info
Old 05-25-2013, 04:04 PM   #11
Wow! This must be the original unit then. The house was built in 1990. It blows cold but weak. I guess it's time to go shopping. Thanks for the quick replies.
Old 05-25-2013, 04:06 PM   #12
The outside unit would not be why it is weak blowing inside. When was the last time the A-Coil on top of the furnace was ever cleaned of any gunk and hair on the coils? You would be surprised at a difference it will make, once the A-Coil is cleaned, along with the outdoor coils of the fur blankets.
Old 05-25-2013, 04:42 PM   #13
Hmmm. I'm not sure Greg. We just bought the place(closing next week). I'll do a search and see if there's any info on the boards about how this is done. That'd be great if that's the problem.
Old 05-25-2013, 05:18 PM   #14
If the Home Inspector did not state in their documents about the condition or appearance of the A-Coil, or operation temps, etc. for the inside & outside units, call a few hvac companies to have them come look at it.
I use a one man operation for doing my hvac & plumbing stuff, same when it comes to roof or structural stuff. A whole lot cheaper than calling those with the big adverts. I have used one of the older companies in our area for root cutting for our main waste drain, due to my guy would have to rent the equipment, and would have cost me more than just calling the company I used for it.
Cleaning the coils on the outside unit, you can do yourself semi-yearly. Disconnect power at the breaker panel & the disco at the unit outside, then use a pump sprayer to soak the coils with coil cleaner, after using a brush to brush off as much of the blanket from stuff like dandelions & Cotton wood fuzz. I did not do our outdoor unit for almost a year and a half, and by the time I got to it last fall, looked like it had a flannel blanket covering the coils.
Just hosed it down with a a garden hose from the backside, then used wide spray at not a high pressure, to wash down the coils on the outside. Clean as a whistle, no coil cleaner needed. You can do the same. As for the indoor coil, call a pro to do that as I stated before, since if they need to pull the coil to do a acid clean, they have the equipment.
Old 05-25-2013, 06:04 PM   #15
Great info! Thanks, Greg. The below walk through makes cleaning the inside parts easy. What do you think?
http://www.handymanhowto.com/2009/06...-coils-part-1/
