Old 06-25-2010, 09:39 PM   #1
how to hook up capacitor
i just bought a new capacitor for my outside ac unit. it has 3 wires red, tan, and brown the new capacitor has fan, therm, and c on it the old one had no markings. how do i hook it up
tazland is offline   Reply With Quote
Old 06-25-2010, 10:15 PM   #2
The wire coming from the contactor goes on C. The wire coming from the compressor goes on herm. Of course fan goes to the fan.
Old 07-01-2010, 05:42 PM   #3
ty for your help i wonder if u could help me again. i came home from work one day and my ac had quit working and it was buzzing and the fan wasnt running. i have replaced the capacitor and the contact relay everything seems to be working properly but the ac isnt cooling. i have cleaned my coils too. this is a split system so i not sre what else i should check next. is there a way i can check to see if it low on freon or should i call a tech out for that
Old 07-01-2010, 06:51 PM   #4
Buzzing is the contactor pulled in but no high voltage present. Check the breaker first. If blows again right away then it's cheaper to call a tech out then buying meters and guages.
Capacitor Replacement on Central Air unit sn2567 HVAC 6 07-21-2012 03:29 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 01:25 PM
problems with capacitor motor for pump joeypants Electrical 13 10-13-2009 05:18 PM
Bad Compressor or Bad Capacitor needhelpbad HVAC 2 07-27-2008 04:20 PM
Maytag Plus Techman2006 Appliances 2 12-12-2007 12:40 PM
