How To Glue On Insulation To Heater Cabinet? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2009, 11:01 PM   #1
Rewards Points: 682
How to glue on insulation to heater cabinet?
I would like to glue a thin layer of insulation to the outside of a wall heater cabinet. Does anyone have any suggestions as to materials?
I would rather not use fiberglass insulation. Would high temp rated silicone rubber work?
darsunt is offline   Reply With Quote
Old 10-23-2009, 02:38 AM   #2
just a thought but you may create an overheating condition by not letting the heat dissipate
kennzz05 is offline   Reply With Quote
Old 10-23-2009, 05:53 AM   #3
An old Tradesmen
Rewards Points: 6,072
Yep.
Plus. If the cabinet is getting to hot. You will be covering up a series problem. And causing a fire hazzard.
Why do you want to insulate it.
Old 10-23-2009, 12:20 PM   #4
Rewards Points: 682
I just want to cover certain spots.
The old wall heater was placed in a spot where it had no clearance. I want insulation where the cabinet is close to the wall.
Old 10-23-2009, 12:37 PM   #5
An old Tradesmen
Unless the install instructions say you can insulate it. You are not allowed.
If the install instructions require X amount of clearance. Thats what you need.
Possible way around with insulation. Is you would need fire resistant insulation. Like used in commercial buildings.
But, your local code enforcement would need to approve it.
Or your insurance company doesn't have to pay, if something goes wrong.
rafter insulation question Jeremy Hillary Boob, PhD Building & Construction 7 08-02-2009 09:19 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
