How To Get AC Compressor To Run 30 Seconds Before Blower - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 05:10 PM   #1
How to get AC compressor to run 30 seconds before blower
How can I get the compressor to cool the A-coil for 30 seconds before the blower engages?
jerral is offline   Reply With Quote
Old 02-05-2013, 05:31 PM   #2
Rewards Points: 1,192
Check out time delay on relays from www.time-mark.com
bobelectric is offline   Reply With Quote
The Following User Says Thank You to bobelectric For This Useful Post:
COLDIRON (02-05-2013)
Old 02-06-2013, 10:21 AM   #3
Rewards Points: 314
its fairly easy. you want to control the fan relay, so just add a time delay relay into the fan circuit. I did something similar to the evap cooler. I turned on the pump 1 min before the fan. I found really cheap delay relays on the internet and wired it in. but be careful, as you are around 220v and that can get you!!!!
bobinphx is offline   Reply With Quote
Old 02-06-2013, 09:04 PM   #4
Missouri Bound's Avatar
Why?
Do you want it your way or the right way?
Old 02-06-2013, 09:45 PM   #5
Rewards Points: 6,652
So you want to shorten the life of the outside unit, why? Relay's are used to usually keep the outdoor unit from coming on right away, if there is a power drop while it is operating, and power comes immediately on.
As long as the outdoor unit and indoor coil are doing their job, and the inside air handler/furnace is also doing its job, there is no need for a 30 second cool down. Matter of fact, with my a/c, I can stick a six pack of beer in the vent, and cool it down within a hour of running, due to always pushing at least 36 degrees, no matter how warm the house is during the Summer.
Air Handler Blower runs for 20 seconds then stops for 3 seconds JohnRoss HVAC 13 02-12-2016 10:53 AM
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Strange oil furnace problem: blower comes on before burner robparrott HVAC 6 12-12-2011 02:55 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Carrier 58MXA Wiring Blower Switch 63012753 HVAC 0 10-06-2009 10:09 PM
