-   -   How to get AC compressor to run 30 seconds before blower (http://www.diychatroom.com/f17/how-get-ac-compressor-run-30-seconds-before-blower-171140/)
jerral 02-05-2013 04:10 PM
How can I get the compressor to cool the A-coil for 30 seconds before the blower engages?
bobelectric 02-05-2013 04:31 PM
Check out time delay on relays from www.time-mark.com
bobinphx 02-06-2013 09:21 AM
its fairly easy. you want to control the fan relay, so just add a time delay relay into the fan circuit. I did something similar to the evap cooler. I turned on the pump 1 min before the fan. I found really cheap delay relays on the internet and wired it in. but be careful, as you are around 220v and that can get you!!!!
Missouri Bound 02-06-2013 08:04 PM
Why? :eek:
gregzoll 02-06-2013 08:45 PM
So you want to shorten the life of the outside unit, why? Relay's are used to usually keep the outdoor unit from coming on right away, if there is a power drop while it is operating, and power comes immediately on.
As long as the outdoor unit and indoor coil are doing their job, and the inside air handler/furnace is also doing its job, there is no need for a 30 second cool down. Matter of fact, with my a/c, I can stick a six pack of beer in the vent, and cool it down within a hour of running, due to always pushing at least 36 degrees, no matter how warm the house is during the Summer.
