-   -   How to fix baseboard heat (gas heat furnace) making GURGLING NOISE? (http://www.diychatroom.com/f17/how-fix-baseboard-heat-gas-heat-furnace-making-gurgling-noise-163164/)
ChicityChicity 11-13-2012 12:44 AM
You can hear the noise in this video
http://www.youtube.com/watch?v=NiFe92DUY7Q
I've just bought the house so this is the first time i turn on the heat. Before that, I changed the thermostat to a HoneyWell Digital one. There was only 1 Red wire but there was no metal jumper connecting R and RC slot (does it have anything to do with this noise?). The heat comes out, everything works but the annoying noise is there. How do I fix this?
Thank you
ChicityChicity 11-13-2012 12:48 AM
and the noise never stops as long as the heat is on.
how 11-13-2012 12:55 AM
The gurgeling noice is from air in your system which needs to be bled. You can post some photos of your boiler and the immediate valve controls so we can advise you how best to do this or you might want to get that boiler properly serviced.
ChicityChicity 11-13-2012 01:00 AM
how much would it cost me to have someone to do the bleeding for me? The previous owner told me the bleed valve is at one side end of the baseboard in the video
ChicityChicity 11-13-2012 01:02 AM
Also, is this any serious problem that would damage the furnace? Thanks for your help.
how 11-13-2012 01:14 AM
If you get enough air into the system you can get air locks that prevent circulation of the water. This will cause overheating and possible venting out of your pressure relief valve depending on the integrity of your exp tank. It usually does not damage anything but can definately result in an unheated home.
beenthere 11-13-2012 05:26 AM
Your baseboard may have radiator ells/bleeder ells on one end. Remove the cover and check. if not, they should be a purge set up near the boiler. post pics of piping and boiler, and we may be able to tell you how to purge the air out, if you don't have bleeders on the baseboards.
TheBobmanNH 11-13-2012 11:12 AM
Just a quick pet peeve but also something to help you when you call a professional to do this for you : systems that heat air have furnaces, systems that heat WATER (ie, yours) have BOILERS, not furnaces.
ChicityChicity 11-13-2012 08:10 PM
The previous owner showed me the ells/bleeder on one side end of the baseboard radiator in the video. How can I bleed the air out by myself? Do I need a pro for this job? I'm no handy man. :(
carmon 11-13-2012 08:47 PM
after reading.... i suggest a service call.... should not be expensive to bleed air....:thumbsup:
REP 11-13-2012 09:16 PM
Many companies have what is called a clean and check service.On this kind of call they clean byurners etc ,they check safty features .It is very comman to have the home owners ask all kind of questions about how their system works and what you should do in the event that something goes wrong.
It sounds as though your air vent is not working.It could also be that the boiler has lost a bit of water and the fill valve is shut off the way the instructions tell you to do.
I believe this would help you out now as well as in the future.
ben's plumbing 11-13-2012 10:45 PM
thanks for being honest about your ability ..I would call for service its worth it ...ben sr:yes:
beenthere 11-14-2012 05:27 AM
A dime or small screw driver is used to turn the bleeder open. Then you let it open until water comes out. Don't open it too far, let it slowly bleed out the air.
If it stops leaving air out and no water is coming out. Then close it, an see if your boiler has an automatic water feed, or just a manual. Add water to system until it reaches bout 12 PSIG, then go back to bleeding the air out.
ChicityChicity 11-14-2012 11:49 AM
Thanks. I don't think I have a boiler water tank. Please see this thread for the photos of my Heating system
http://www.diychatroom.com/f17/its-c...1/#post1016778
Q: Do I keep the heat running while bleeding or turn it off? It doesnt sound that hard, so I will give it a try first.
beenthere 11-14-2012 06:05 PM
For bleeding, you can leave the boiler on.
