How To Find Gas Line In Wall - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2013, 01:34 PM   #1
How to find gas line in wall
I want to put a doggy door through an outside wall, but I think a gas line may run through that area of the wall. Is there an easy way to verify that the line is or is not in the area where I want to put the door?
I could use a hole saw to core out a piece of drywall and take a look or feel around in the insulation, but then I have to close it and refinish the wall when I find the gas line is there, which I think it is.
johneakins is offline   Reply With Quote
Old 03-20-2013, 04:19 PM   #2
Bill Kearney
Rewards Points: 1,174
Start by tracing where the gas line comes from and goes to. Consider checking with the county for the permit for the gas work. If there was one pulled then it might show where it was routed. But I'd lean toward the line either being below in the basement of crawl space or coming down from the attic.
wkearney99 is offline   Reply With Quote
Old 03-21-2013, 09:44 AM   #3
Thanks, Bill
Thanks for the suggestions. No basements here. You're the second person to suggest the line comes from the attic where the furnace is, even though it's a straight 20' shot from where the gas comes into the house to where it comes out for the grill. If it does come from the attic, maybe it's hugging the corner studs and out of the way for the door. Still I can't know for sure without removing some dry wall and looking around. (Just thinking by typing.) Thanks again.
Old 03-21-2013, 10:15 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 2,236
the gas co/utility has a meter/detector for finding underground lines. not sure how it works but they may be able to help you for free or a fee. due to liability concerns they will insist you carefully open the wall for manual inspection and that definetly will be on their work order/report. try tapping on the pipe from where it leaves the attic or wherever and have another person listen downstream. put a glass to the wall and press your ear against it to hear what is in the wall/old trick we used to listen to the neighbors in my appt. as well.
Old 03-21-2013, 10:39 AM   #5
Thanks, Yuri
Thanks for the suggestion, but would be easier to just cut into the wall and look around because there's no room in that corner of the "attic" (just the space between the roof and ceiling and filled with insulation) to get to the pipe.
Old 03-21-2013, 10:47 AM   #6
Roofmaster
Rewards Points: 2,210
Funny Yuri, I didn't take you for the nosy type
Old 03-21-2013, 12:33 PM   #7
Hvac Pro
yuri's Avatar
Yeah it would be easier to just open the wall. DO NOT use power tools, just a utility/box cutter type knife or small hacksaw blade on a hand hacksaw/push pull type saw and be very careful. If the wall is hollow you may be able to rent a bore scope/inspection camera from HDepot. If the gas line is black steel pipe then it is hard to damage but if it is copper then you REALLY got to be careful.
Old 03-21-2013, 12:36 PM   #8
Hvac Pro
yuri's Avatar
Not nosy, just wanted to know if the son of a b**tch was sleeping at 1 AM so I could phone him and hang up to get back at him for all the noise he made and being a total arzehole. I hated renting, nothing but lunatic neighbors.
It worked and he started yelling and pounding on the other neighbors wall (this was B4 call display), guess they did not get along either.
Old 03-21-2013, 12:58 PM   #9
Rewards Points: 1,228
Possibly a metal detector would locate and track it .
Old 03-21-2013, 01:24 PM   #10
Rewards Points: 194
To be sure I would open the dry wall being very careful if the pipe is there. There's no guessing involved once you do that.
Larryh86GT is offline   Reply With Quote
Creating doorways/supporting wall issues NWVintage Remodeling 2 12-19-2012 03:19 PM
leaning garage wall and sagging roof line. jrb619 Building & Construction 27 10-22-2012 06:29 AM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
GROUND - Wall Oven - Water Line Acceptable? Mickey53 Electrical 5 09-29-2008 12:02 PM
