How Far To Run Dryer Vent? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 06:38 PM   #1
How far to run dryer vent?
I bought an existing home without an outside dryer vent. The w/d had been moved from the basement (and all connections and vent sealed off) to the middle of the house. The previous owners simply vented their gas dryer through the 1st floor room into the basement through an unfinished spot. That's a no-go for me. I need to run a vent for my dryer now. The closest exterior wall is 12 feet away. I can run the vent along a joist bay but I have to go through finished ceiling and then end up smack into an existing deck with no access under. I have a crawl space I can access and run the vent to an outlet near other vents next to my a/c unit. But that route is 36 feet.
Question: Can I safely run gas dryer vent 36' with at least one 90 or at least a 45 bend 6-9 feet prior to exit? If so can I use 4" pvc? Will I have a problem with water vapor collecting in this long pipe? Should I pitch it up or down and how much? 36' is a long way in my mind.
bigmark77 is offline   Reply With Quote
Old 11-28-2011, 07:31 PM   #2
Rewards Points: 484
I wouldnt use pvc for the dryer vent, use the 4" round metal pipe.
As far as the length, 36 feet is going to be a long stretch for that thing, especially adding the extra fittings that you want.
Try to find another route that isnt as long.
Also, dont use screws in the metal piping when you assemble it, the screws will attribute to lint buildup
sammy37 is offline   Reply With Quote
Old 11-30-2011, 03:02 PM   #3
Not what I wanted to hear but I was hoping for the best. the long run worries me so I better go shorter. I can't go out back without re-doing a deck. I may have to look at a front of the house option. Thanks for the reply.
Old 11-30-2011, 06:49 PM   #4
35 Feet
45 degree counts as 2.5
90 counts as 5
No Screws into pipe tape only
IBC 2006
BSB00 is offline   Reply With Quote
Old 12-03-2011, 06:12 PM   #5
Registered User
Rewards Points: 5,492
I recommend a shorter route to prevent lint build-up and condensation. Look up your dryer model on line for the maximum safety run. Use a type "A" termination hood rather than Type "B' for 50% more opening door flapper;http://www.appliance411.com/faq/dryer-vent-length.shtml
No flex pipe, screws, or pitch; metal smooth-walled pipe only: http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Exit hood 3' minimum from other openings (door, window, fresh-air intakes) to building as per code.
Gary
Old 12-03-2011, 06:16 PM   #6
Rewards Points: 13,458
Middle of the house is the worst place for a location for a dryer.
Old 12-03-2011, 07:27 PM   #7
Rewards Points: 484
Our dryer is in the middle of the house, our vent used to run horizontaly all the way through the attic to the end of the house. When I replaced my roof in the spring, I ran a new vent straight up through the roof and did a goosneck with two 4" adjustable 90's, works great.
To the OP, can you run your vent up through the roof?
Old 12-03-2011, 08:56 PM   #8
Missouri Bound's Avatar
Appliance411 FAQ: How long can my dryer vent be? Maybe this will help your decision....scroll down to see mfg. details and specs.
Old 12-03-2011, 09:17 PM   #9
30 year tech
hvac122's Avatar
Code here is 20' and 1 elbow. The only way it can be longer is if the manufacturer allowes it and we need to prove that with specs to the inspector. 35' is way to long.
hvac122 is offline   Reply With Quote
Old 12-04-2011, 12:08 PM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I know this isn't what you asked, but have you taken a good hard look at the washer too. Does it have the proper hoses (not the old black rubber ones), a pan with drainage, or any warning system if there is a leak?
I'm no expert, but if the PO installed the dryer like this, it makes me wonder what kind of a job he did on the washer.
I know it's a lot more convenient to have them upstairs, but between the major repair $$$ a leaking washer can cause, and the potential CO issues of a gas dryer, I would give serious consideration to moving them both back to the basement.
Edited to add: Welcome to the forum, too! I was born and raised in Lake County.
Tags
dryer venting
Using 4" PVC for dryer vent Thurman Appliances 10 01-10-2016 09:28 AM
Problems with inside the wall dryer vent darsunt Appliances 2 11-08-2011 06:58 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 10:39 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Dryer vent ponch37300 General DIY Discussions 10 01-21-2009 04:26 PM
