How To Efficiently Use My Prestige Solo 110 NG Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 11:22 AM   #1
Just call me Andrew
Rewards Points: 1,020
How to efficiently use my Prestige Solo 110 NG Boiler
I have been reading a lot on how to achieve max efficiency from my new boiler. I have an outdoor reset installed, and the settings are as follows:
Coldest day: 10*
Minimum Setpoint: 100*
Max setpoint: 180*
My house has cast-iron radiators.
Normally, with my old oil boiler, i kept the house at 70* during the day, and setback to 60* at night. I am willing to change if it would save money.
I have been reading that using lower boiler water temp, smaller setbacks (maybe setback to 66* at night) so that the circulator is more consistently running increases efficiency.
How do I figure out the most efficient way to heat the house? Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 12-18-2010, 01:19 PM   #2
An old Tradesmen
Rewards Points: 6,824
With cast iron rads. You shouldn't need more then 160 water temp. Many houses get away with 140. All depends on how much radiation your house has in it.
10 degrre setback is fine. As long as you don't want quick recovery.
Old 12-18-2010, 01:23 PM   #3
Just call me Andrew
So is it better to have 10 degree setback and set the thermostat to come back up to 70 like 3 hours before-hand so it recovers in time, or should I just use a smaller setback? Which is more efficient?
Similarly, is it better to use lower temp water and set the thermostat to recover earlier, or use higher temp water and have the recovery time be shorter?
Andrew
Old 12-18-2010, 01:34 PM   #4
An old Tradesmen
Use a thermostat with intelligent recovery. that way it will start to recover when it needs to. Weather it be 30 minutes, or 3 hours.
using higher temp water, waste more fuel. It doesn't save any money.
Old 12-20-2010, 10:41 AM   #5
Just call me Andrew
My t-stat does have a smart-recovery option. I tried it, and it didn't seem to work. Does it take a few days to learn?
Andrew
Old 12-20-2010, 06:48 PM   #6
An old Tradesmen
Yes. it can take 7 or more days for it to learn your house.
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 02:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 09:55 PM
Prestige Boiler keeps blowing a fuse, no heat for days!! ryan04 HVAC 13 09-25-2010 06:18 PM
Boiler size Bonnie Youngs HVAC 29 07-10-2009 07:58 PM
