How Easy To Install Hydronic Heating In Small Bathroom - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 02:51 PM   #1
Rewards Points: 81
How easy to install hydronic heating in small bathroom
Hi, i have a small bathroom, probably about 100 sq ft. that sits right above my oil burner. My house has baseboard heat. I am thinking hydronic is the way to go because of this. I can do plumbing and am pretty handy, but never did it before.
What is the easiest and most efficient way to do this? Will i need baseboard heat in my bathroom along with the hydronic flooring heat? What parts will i need? I am looking for some specific details, never did this.
mayhem69 is offline   Reply With Quote
Old 10-18-2009, 02:56 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Are you talking about retrofitting radiant floor heat? The temperature is much less than for typical baseboard, <=130F vs. 180F for baseboard.
It can be done but need's it's own loop.
I would just loop in a hydronic heated towel rack.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 10-24-2009, 07:24 PM   #3
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
It's much easier to install an electric radiant system, low or line voltage, than to try to heat such a small area off your existing boiler.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 10-25-2009, 07:35 AM   #4
Rewards Points: 81
yea, i realized that electric radiant flooring is the way to go, so that's what i will be installing. I found this seller on Ebay,
http://cgi.ebay.com/Shield-Floor-Hea...item562b310ec5
what do you think? What kind of surface is best to work with when laying down this cable? Hardibacker?
Old 10-25-2009, 08:32 AM   #5
Civil Engineer
Rewards Points: 4,954
If you have never done this before, you are biting off a pretty good chunk of apple. Not saying you can't do it, dozens of people on this forum (myself included) have successfully installed electric heat, but here is a brief checklist of what you will need to do:
1. I assume you are putting in tile, so you will need to remove the old flooring, verify that the floor is stiff enough to suppot tile, then prep the surface.
2. Typically the electric mat goes in a layer of thinset on top of the subfloor, in my case I put it directly over the plywood subfloor. Installation of the mat requires basic electric wiring skills, you need to install a new circuit, wire in the thermostat, check the wire for proper resistance, attach the wire to the floor, wire in the floor sensing thermocouple, and place thinset over the wire.
3. Then you need to tile over the thinset. In my case, I used Ditramat under the stone tile, so there was an extra step in the process.
That is the overall process, each step has been discussed at length in this forum, run a search and you will find lots of useful tips.
Old 10-25-2009, 09:39 AM   #6
Rewards Points: 81
doesn't seem too difficult, i have basic electical skills and can lay tile. If i didn't think i could handle this, i wouldn't attempt it.
Old 10-25-2009, 09:58 AM   #7
Rewards Points: 266
It wont be too bad to install. I myself wouldnt go with the seller you listed as the shipping is HIGH and they are from Bulgaria. If your in the states, I would search for a seller closer to eleviate lost in the mail problems. Im sure the seller is fine with 100% positive feedback but I keep all my ebay purchases in the United States.
Good luck
What have I done is offline   Reply With Quote
Old 10-25-2009, 10:56 AM   #8
Rewards Points: 81
Good luck
yes, i know the seller is in Bulgaria, that doesn't concern me. I can't find any sellers in the US that comes close to this price. I can pick up a programmable thermostat to go along with that and keep the final price down to around $200.
Old 10-25-2009, 03:21 PM   #9
Rewards Points: 150
Mayhem
Here are some more important things to considerwhile installing:
I see the element you are buying is a single cable in a coil. That's the same design we use for our low voltage systems.
DON'T use a stapler. Use "P" shaped cable clips. You can get them at HD. Then you can use 1" galv roofing nails to hold them down and protect the element at the same time.
Leave the nails almost tight until you are finished laying out the wire. Then bring them home when you are sure you're layout is right.
I'm not sure if the instructions give you an explanation of how to calculate your spacing so follow this rule:
Box off the space and get your exact square footage of coverage. Then devide that sq ft number by the foot length of the element you get and then multiply x 12. This will give you your spacing (in inches) between runs. Maintain the same spacing all over except at the walls or cabinets. Use 1/2 the spacing between the cable and the wall there. So if your calculation gives you a 4" spacing, you want the cable to be 2" from the wall or vanity, etc.. From there out, you want ALL the spacing, even the turns, to be at your calculated figure.
check these pictures for reference:
http://www.comfortradiant.com/gallery_flzprimary.php
Take your time and it will work out fine.
Old 10-25-2009, 03:56 PM   #10
Rewards Points: 81
thanks warmsmeallup!
Konecto flooring LookoutRanch Flooring 23 03-08-2010 03:32 PM
How easy to install hydronic heating in small bathroom mayhem69 Flooring 1 10-18-2009 03:29 PM
12x12 tile on small bathroom walls???? trueform General DIY Discussions 4 06-23-2008 11:34 PM
two easy bathroom drywall questions amakarevic Building & Construction 2 04-30-2008 09:17 AM
