How Easy/hard Is It To Build Your Own Refrigerator? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-31-2013, 02:45 PM   #16
Rewards Points: 582
see post #2 ...USE THE MINI FRIG...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (03-31-2013)
Old 03-31-2013, 07:13 PM   #17
Rewards Points: 242
didn't see the 32 degree part. what are you going to use it for?
hvac instructor is offline   Reply With Quote
Old 04-01-2013, 07:54 AM   #18
Rewards Points: 2,638
It shouldn't be too hard. Everybody here is thinking compressors and evaporators..., but you can buy solid state cooling modules. Its called the Peltier Effect, when you put power to a semiconductor, one side gets hot, one side gets cold. Do a google search on "solid state cooler".
The solid state cooling module is commonly used on coolers that you can plug into car's cigarette lighter. You could likely buy such a cooler for less than you can make your own, but then you wouldn't be able to say that you built it yourself.
Here is how one fellow did it: http://www.thesurvivalistblog.net/dirt-cheap-fridge/
SPS-1 is online now   Reply With Quote
Old 04-01-2013, 03:48 PM   #19
An old Tradesmen
Rewards Points: 7,832
As long as the temp where he is keeping the cooler is under 82. He may need 2 peltier plates depending on the load he has in the cooler. however, they are not actually efficient at cooling. Which may not be of any concern to the OP.
Old 04-01-2013, 11:27 PM   #20
Experienced HVAC Tech
HVAC1000's Avatar
those cooling plate work but the quickly multiply your electric bill. Been, your list also needs and EPA 608 certification
HVAC1000 is offline   Reply With Quote
Old 04-02-2013, 04:39 AM   #21
An old Tradesmen
Not if he uses R134A.
Old 04-02-2013, 10:18 AM   #22
Rewards Points: 186
I looked into this briefly when building a refrigerated computer... basically I disassembled a regular fridge that was lying by the side of the road and VERY CAREFULLY rearranged the evaporator coil into a cooler, and placed the condenser fins below a box fan... a huge contraption. 1/4hp pump to move the subzero temp liquid through the system. It never really worked very well because I couldn't keep the refrigerator from cycling too much... I got it down to like -30*F at one point but that was I assume the lower limits of R12 or whatever refrigerant old fridges use.
Like people said, the mini fridges are very fragile, and have tubing that can NOT be bent, i.e. it's very delicate, and if you move it in the wrong way it will kink and get destroyed.
You also didn't mention what kind of load you were putting on this. If you're growing some rare pitcher plants, then you have no real heat load except for the light bulb... if you are trying to cool a computer, you know you have to calculate the CPU processor + whatever is in that loop and in the end a mini fridge can't keep up with that load. We need more info.
Basically, you can't realistically DIY a small a/c system. You'll spend hundreds of dollars and hundreds of hours. I know I read an a/c text book in that quest, bought the compressor, gauges, an evaporator from the dump... and then gave up. But I had a great time in the quest!
Custom a/c systems are pricey, and very cool, I've seen them in some houses where the condensers were in a remote closet.
Ocelaris is offline   Reply With Quote
Planning to build First Spec Home, Need Advice ahb2012 General DIY Discussions 53 05-27-2013 06:30 AM
How much more would it cost to build another story? reveriereptile Building & Construction 5 01-19-2012 10:51 PM
How do I build this sofft? swt99svt Building & Construction 7 01-17-2012 06:26 AM
refrigerator not cooling correctly mrswow Appliances 4 01-05-2012 09:36 PM
Refrigerator Freezing Up tgillis HVAC 0 10-08-2011 01:00 PM
