How To Drain/remove A Single Radiator - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2007, 07:14 AM   #1
how to drain/remove a single radiator
I am remodeling my kitchen and would like to drain/remove one radiator while remodeling the room.
I dont know how I am supposed to do this. I know that I can shut off the incoming water by turning the knob on the top. I don't know if my radiator has a lockshield valve. What do I do if I dont have a lockshield valve?
Attached is a picture, let me know what you would do.
DanBress is offline   Reply With Quote
Old 12-27-2007, 12:02 PM   #2
Custom Cabinet Maker
If you dont need the heat on than drain system and pull it out. If you need heat then you still have to drain it a bit, pull radiator and then BUILD A BYPASS TO RECONNECT THE PIPES SO YOU HAVE A LOOP FOR YOUR HEAT
skymaster is offline   Reply With Quote
Old 12-27-2007, 10:36 PM   #3
Union HVAC Tech.
Drain the lines and cap them both.
bigMikeB is offline   Reply With Quote
Old 12-28-2007, 10:49 AM   #4
Mike: if you dont connect them you have turned off the heat loop. on every radiator you have a feed and a return, they form a continous loop and to continue to have heat without that radiator it has to be connected :}:}
Old 12-28-2007, 01:13 PM   #5
If this is true, then wont turning one heater off(by turning the knob) "break" the loop, and shut down heat everywhere? I thought each radiator was a branch off the main line.
Old 12-28-2007, 01:39 PM   #6
Dan; If the actual "loop" is underneath the floor and you are tying the radiators in with the proper "t's" then you are correct. Since I cannot see the sustem I said to tie them together becasue this way I know everything will remain the same regardless of how it is piped. Just CMA .
If you have regular baseboard heat ,that is one loop only and you cannot just take a section out without reconnecting that section with pipe.
A single pipe Steam system you can just shutoff a radiator without a problem.
Old 12-29-2007, 01:28 AM   #7
Union HVAC Tech.
I think you'll find that if a radiator has a valve on it that it's piped in a mono flo tee system, removing one radiator or all of them won't change flow in the loop.
Old 12-30-2007, 01:00 PM   #8
OK, I am not really experienced with this sort of thing so I am going to describe what i plan to do, and what i think will happen each step of the way.
I have a two pipe radiator by the way.
1) I will turn off the incoming hot water
2) I will open the bleed valve which will cause air to go into the radiator, and all the water into the radiator to go out of the drain pipe.
??? How long do i do this? How do i know when the radiator is empty? Will air get into the return pipes/the rest of the system?
3) i will use a monkey wrench to disconnect the send and the receive pipes from the radiator
at this point the receive pipe will be open. Is it possible that the lack of pressure forcing water in to this pipe will cause water to flow back out of this pipe? If this doesn't happen wont air get into the pipe?
4) Do i need to cap the receive pipe while I am doing my renovation?
Old 12-30-2007, 01:12 PM   #9
Union HVAC Tech.
There will be full system pressure on the return side of the loop. The system will need to be shut off, the water feed closed and the loop drained below the point of the radiator your removing, then you can safely remove it and cap the both pipes. Most old radiator valves don't shut off 100% because of debris on the seat. You will need to refill the system back to operating pressure and maybe do some bleeding after you bring it back online after the radiator is removed.
Old 12-31-2007, 11:25 AM   #10
Do you have access to the pipes below the floor?
Can you post a photo of the pipes below the floor?
Do they connect with an elbow or a "T" below the floor?
redline is offline   Reply With Quote
Old 12-31-2007, 11:36 AM   #11
Directly below the floor is an elbow to another pipe which I believe connects to the main system with a T. I will take pictures tonight.
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 07:09 AM
Radiator leak nonamemark Plumbing 4 11-16-2007 11:50 AM
Feeding multiple subpanels with a single generator monsoon Electrical 8 10-02-2007 04:25 PM
Plastic caps /wheel heads on radiator PianoMan Plumbing 1 10-18-2005 07:25 PM
