How Does Hole In Gas Furnace Cabinet Contribute To Carbon Monoxide In Crawl Space. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 01:01 PM   #1
Question
How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space.
I just recently had my gas furnace replaced. I called in a professional to diagnose why we could smell gas at times, especially when the heat started up.
The diagnosis was that we needed a new furnace due to a rusted out hole in the metal cabinet near the condesate drain. The professional informed that this was source of not only CO and gas into the crawl space but allowed CO to be pulled into the burner (flame) area reducing effeicency to dangerous levels. (This is vented with PVC pipe only)
Here are a couple of photos from the old extracted unit. To me this looks like a closed air circulation system within the cabinet. Can someone explain to me how the cabinet hole was causing this problem?
I have attached a photo. Top side in this photo was actually bottom side when installed. Small lines appear to be condesate lines directed toward vent point. Large pipe end at rust whole appears to be a non-capped branch of exhaust. Other end went to the PVC pipe vent. This is a Lennox GHR26 series furnace.
Just courious, thank you.
How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space.-furnace-004.jpg   How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space.-furnace-001.jpg   How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space.-furnace-002.jpg   How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space.-furnace-003.jpg
Chris H is offline   Reply With Quote
Old 10-08-2008, 01:56 PM   #2
The condensate is very toxic and can eat away metal as in your pictures. My guess is that there was a leak in the condensate system and over the years did the damage that you see.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-08-2008, 06:33 PM   #3
oops, did I do that!
Was there two PVC pipes, one for the vent the other for combustion air both going to the outdoors?
8 Ball is offline   Reply With Quote
Old 10-08-2008, 06:55 PM   #4
1610 CUB's Avatar
Rewards Points: 150
The professional informed that this was source of not only CO and gas into the crawl space but allowed CO to be pulled into the burner (flame) area reducing effeicency to dangerous levels. (This is vented with PVC pipe only) ....."You can't smell CO !"
1610 CUB is offline   Reply With Quote
Old 10-08-2008, 07:01 PM   #5
Those holes dont appear to be anywhere near the heat exchanger, and if the combustion air inlet was piped to the outdoors...hmm.
It looks like the condensate was leaking and rotted a hole in the cabinet, but the cabinet isnt part of the sealed system, at least not where its rotted.
Old 10-08-2008, 07:20 PM   #6
1610 CUB's Avatar
Rewards Points: 150
I agree 100% They nay have had a gas leak that they smelt when it started.
Tags
gas heat , hvac , new furnace.
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 04:29 PM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 02:06 PM
Carbon Monoxide Kills TRUSTEDTRADESMEN General DIY Discussions 1 06-23-2008 08:52 AM
32 inch high crawl space can a furnace fit tommar HVAC 4 02-20-2008 06:28 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
