-   -   How does hole in Gas Furnace cabinet contribute to carbon monoxide in crawl space. (http://www.diychatroom.com/f17/how-does-hole-gas-furnace-cabinet-contribute-carbon-monoxide-crawl-space-29586/)
Chris H 10-08-2008 01:01 PM
4 Attachment(s)
I just recently had my gas furnace replaced. I called in a professional to diagnose why we could smell gas at times, especially when the heat started up.
The diagnosis was that we needed a new furnace due to a rusted out hole in the metal cabinet near the condesate drain. The professional informed that this was source of not only CO and gas into the crawl space but allowed CO to be pulled into the burner (flame) area reducing effeicency to dangerous levels. (This is vented with PVC pipe only)
Here are a couple of photos from the old extracted unit. To me this looks like a closed air circulation system within the cabinet. Can someone explain to me how the cabinet hole was causing this problem?
I have attached a photo. Top side in this photo was actually bottom side when installed. Small lines appear to be condesate lines directed toward vent point. Large pipe end at rust whole appears to be a non-capped branch of exhaust. Other end went to the PVC pipe vent. This is a Lennox GHR26 series furnace.
Just courious, thank you.
Marvin Gardens 10-08-2008 01:56 PM
The condensate is very toxic and can eat away metal as in your pictures. My guess is that there was a leak in the condensate system and over the years did the damage that you see.
8 Ball 10-08-2008 06:33 PM
Was there two PVC pipes, one for the vent the other for combustion air both going to the outdoors?
1610 CUB 10-08-2008 06:55 PM
The professional informed that this was source of not only CO and gas into the crawl space but allowed CO to be pulled into the burner (flame) area reducing effeicency to dangerous levels. (This is vented with PVC pipe only) ....."You can't smell CO !"
8 Ball 10-08-2008 07:01 PM
Those holes dont appear to be anywhere near the heat exchanger, and if the combustion air inlet was piped to the outdoors...hmm.
It looks like the condensate was leaking and rotted a hole in the cabinet, but the cabinet isnt part of the sealed system, at least not where its rotted.
1610 CUB 10-08-2008 07:20 PM
I agree 100% They nay have had a gas leak that they smelt when it started.
