How Do You Test A Gas Valve On Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 07:01 AM   #1
Exclamation
How Do you Test a Gas Valve on Furnace?
I have a Gas Furnace that is not working properly. The gas furnace is a Tempstar 5000 (model: NUGE075BG01).
The furnace has an Intermittent Pilot Ignition System. It has a Honeywell gas valve and a Honeywell continuous ignition module (model S8600M). Here is a picture of how the module looks: http://i39.tinypic.com/14t8ttx.jpg
Here is my furnace problem: The pilot lights, but main burner does not come on.
Generally, I know how to use a voltage meter.
How do I test the gas valve to see if the Main Valve is getting voltage? Where do I put the voltage meter probes? Am I testing for 24VAC (alternating current)?
Also, can this problem be caused by a dirty flame sensor?
Please help me as soon as you can. Thanks.
Janine1 is offline   Reply With Quote
Old 12-05-2011, 07:27 AM   #2
Yes Jan it could be just a dirty flame sensor.You want to put your meter on VAC (volts alternating current)
put one of the leads on MV (main valve ) and the other on MV/PV this is your common terminal. If you read 24 vac then your valve is bad.......if you read anything other then 24 vac (less) then the control is not telling the valve to open and yes it may be the flame sensor.
harleyrider is offline   Reply With Quote
Old 12-05-2011, 08:27 AM   #3
Thanks!
Thanks for your reply! As soon as I get home from work, I will try this and let you know if it works. Thanks.
furnace gas valve okweldit HVAC 2 10-01-2011 08:30 PM
which wires do in touch to bypass the stat to test a furnace? brokenhammer HVAC 3 01-01-2010 09:30 PM
Leaky furnace valve billinak HVAC 9 11-01-2009 07:11 PM
Leaking Presure valve on furnace Carloscda Plumbing 7 02-12-2009 01:27 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
