How Do You Seal Holes In House From AC Hoses? - HVAC - DIY Chatroom Home Improvement Forum
Old 05-16-2014, 10:45 PM   #1
Rewards Points: 654
How do you seal holes in house from AC hoses?
How do you seal holes in house from AC hoses? The pictures show the two such areas that I need to seal. The bigger PVC pipe is now being sealed by plumbers putty. I don't know if this type of material is a viable material to seal such an area. I don't think that this is a good material to use on the other hoses being shown as the hole is to big to fill in with plumbers putty.
I have heard of something called duct seal. Is this something that can be used? if so, where can it be purchased? Is it called by something different? Thanks.
How do you seal holes in house from AC hoses?-ac.jpg   How do you seal holes in house from AC hoses?-ac1.jpg
kennykenny is offline   Reply With Quote
Old 05-16-2014, 10:54 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Good high quality white silicone is what I use and my company. Duct seal is like heavier plumbers putty and will dry out, shrink, crack and fall out in a year or two. plumbers putty is meant for putting under sinks B4 you set them down and keeps water from going underneath. not meant for anything else. Duct seal is silly putty that kids used to have and a bit heavier.
Silicone, plain and simple.
Old 05-17-2014, 01:00 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
anything is fine for that scenario. Real question is, and now that we know that heat penetration is a concern of yours (last and least amount being copper line set) is what's your goal? Who led you to believe that that was a serious energy consumption concern and why?
Attic sealing is where your attention needs to be focused as well as window(s) sealing.
that's where your money is being taken advantage of concerning heat loss.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 05-17-2014, 09:26 AM   #4
Rewards Points: 654
Yes energy loss is a small concern but I want to seal the holes to reduce the chance of animals, insects and other things entering inside.
I have ready addressed the attic and window issues. Thanks.
Old 05-17-2014, 10:41 AM   #5
Rewards Points: 1,192
That service disconnect is too low,leaning toward inaccessible.
bobelectric is offline   Reply With Quote
Old 05-17-2014, 01:35 PM   #6
Rewards Points: 416
I thought I was reading the same book but some has torn two complete pages from my copy.
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 11:32 AM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 11:58 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
