How Do You Ground York Furnance Control Board - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 09:26 AM   #1
How do you ground York furnance control board
Recently bought a replacement control board for my 14 year old York furnance. The replacement part number is 21-33102956000. I am getting a repeating "nine red blinks" on the LED error indicator. Tha means polarity or grounding problem. My old board grounded through a screw that connected the board to the sheet metal brace. The hole in the old board had a metal tab (labeled on board as ground) in the screw hole...establishing the ground. I don't see a similar grounding mechanism for my new board. I never had the grounding error code before...so I am assuming it is something to do with the new board. Any ideas? Thanks. Garry
garryshaf is offline   Reply With Quote
Old 01-24-2010, 09:30 AM   #2
An old Tradesmen
Rewards Points: 7,352
Make sure that the transformer connections to the board aren't reversed.
You can also run a wire from the boards common to the chassi(be carefull that polarity is correct first, or you can smoke the new board).
Old 01-24-2010, 09:51 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
I had the EXACT same problem. Change the (2) 24 volt wires from the transformer around on the new board, reverse them. ie: switch R and C around.
Old 01-24-2010, 10:51 AM   #4
Terminology
When you say "common" ... I take it that can mean connect ground wire from a "neutral" lead to the chassi. There is another empty lead called "park" ... Thanks. Garry
Old 01-24-2010, 10:55 AM   #5
Hvac Pro
yuri's Avatar
Carefully look at the the power transformer. The primary side is usually black and white (PRI) and 120 volts. The secondary side (SEC) is blue or yellow and 24 volts and attaches to the board as SEC. Switch the 2 secondary wires positions (one for the other) on the board. The old board was not polarity sensitive, all new ones are.
Old 01-24-2010, 10:58 AM   #6
An old Tradesmen
No.
Common is from the transformer secondary side.
One terminal is Marked R or +, the other is marked C or -, the C/- is common.
A neutral is never a common.
park terminal to put unused blower motor wires, so they aren't hanging in mid air, or shorting out against something else.
Old 01-24-2010, 11:36 AM   #7
Fixed! Thanks.
Beenthere, Yuri. I switched the two secondary wires from the transformer around on the board and furnance is now working. THANKS! Garry
Old 01-24-2010, 11:45 AM   #8
Hvac Pro
yuri's Avatar
No Problema. Pay it Forward and Help someone else.
Old 01-24-2010, 11:48 AM   #9
An old Tradesmen
Congrats.
Its a fairly common thing when going from 1 style board to another.
Old 01-24-2010, 11:50 AM   #10
Hvac Pro
yuri's Avatar
I didn't know that until a month ago. Was 2 steps away from calling the new board bad and getting another one and egg on my face. I don't see too much York where I am.
Old 01-24-2010, 11:56 AM   #11
An old Tradesmen
I'd almost swear the change the polarity of the boards every so often just to screw us up in the field.
But I can't prove it.
Old 01-24-2010, 12:06 PM   #12
Hvac Pro
yuri's Avatar
Now we have a conspiracy on our hands. Oy. Freedom 55 is lookin good now.
Tags
control board , furnace , ground fault , york
Whirlpool refrig. problem ken1415 Appliances 147 02-25-2017 12:27 PM
York gas heater control board replacement spyvan HVAC 5 12-29-2008 07:12 AM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
Ruud a/c control board replacement ? kourso HVAC 1 07-20-2006 09:33 PM
