How Do You Figure Out What Size Vents/ducts To Put In? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 10:33 PM   #1
Rewards Points: 164
how do you figure out what size vents/ducts to put in?
I have limited space and bought a 6" flex duct tube and a 10x6 register to see if it would fit where I want it to go. It'll fit just fine. So the question is how much flow do you get from this size duct?
I have NO central air and wanted to at least get the vents in place now that I have the roof mostly off.
Am I looking at this the wrong way? For example, if I use 6" duct through out the house, then if 1 room is twice the size of the others, just have 2 ducts in there.
Or is this more of using baffles/limiters to restrict flow to some to get more to others?
KarlJay is offline   Reply With Quote
Old 11-14-2010, 06:21 AM   #2
An old Tradesmen
Rewards Points: 6,576
A 10X12 bedroom on the north side of the house needs less cooling then a 10X12 on the south side of the house.
A 20 foot long piece of duct moves less air then a 10 long piece of duct.
A 20 foot long piece of duct ran straight moves more air then a 10 long piece of duct with 3 90 turns in it.
A room by room load calc will tell you what size A/C you should have. And tell you how much air each room should get. Which then allows you to size your duct work.
http://hvaccomputer.com/talkref.asp
Its worth its 50 bucks.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 11:33 PM
what size trowel for 4 1/4 x 4 1/4 tiles? Jim W Building & Construction 5 06-21-2009 10:27 PM
Room size X floor tile size deck hand Flooring 4 04-08-2009 05:42 PM
