Old 10-31-2012, 11:29 AM   #1
how do you check heat sensor on pilot assembly
burner will stay on for about 30 seconds gas valve will close then the restart relay will open gas valve again and restart cycle over .
hawkshaw is offline   Reply With Quote
Old 10-31-2012, 11:52 AM   #2
how
Make & model would help. Lots of different systems out there. If you have a flame rod then a scotch pad or fine steel wool works for cleaning it.
how is offline   Reply With Quote
Old 10-31-2012, 06:41 PM   #3
alittle more information please ben sr
ben's plumbing is online now   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
